Hello,
I am having issue with Auto renew of LetsEncrypt SSL on ISPConfig panel.
#Scenario
Given below is an Error I get when auto renew failed and try to manually re-generate the certificate
#Error
Failed authorization procedure. shop.equinetreatments.com (http-01): urn:acme:error:unauthorized :: The client lacks sufficient authorization :: Invalid response from http://shop.equinetreatments.com/.well-known/acme-challenge/PH7Z4LPq0ZwAxXS8PrVNMGNd4Y7XWk5PolTnlwFN6uU: “
<ht”
In order to fix it I will have to manually change the symlynk at /usr/local/ispconfig/interface/acme folder to point it to document root of domain to which I want to generate SSL
root@server:/usr/local/ispconfig/interface/acme# ll
total 12K
drwxr-s— 3 ispconfig ispconfig 4.0K May 24 08:29 .
drwxr-s— 9 ispconfig ispconfig 4.0K May 24 08:30 …
drwxr-s— 3 ispconfig ispconfig 4.0K Dec 29 2016 well
lrwxrwxrwx 1 root ispconfig 47 May 24 08:29 .well-known -> /var/www/clients/client1/web11/web/.well-known/
root@server:/usr/local/ispconfig/interface/acme# unlink .well-known
root@server:/usr/local/ispconfig/interface/acme# ln -s /var/www/clients/client1/web3/web/.well-known/
Is there any permanent fix for this issue ?
