Letsencrypt Certificate Not Recognized as SSL
My domain is: hprauto.com
My web server is (include version):Apache 2.4.33
The operating system my web server runs on is (include version): Mac High Sierra
My hosting provider, if applicable, is: network solutions
The version of my client is (e.g. output of certbot --version or certbot-auto --version if you're using Certbot): Certbot Not Supported-Created the certificate using latest Certbot on a Mac Monterey machine
I have loaded the certificate into my keychain. It is trusted. When I assign the certificate to the website using Server App, the certificate is not considered SSL.
Thanks
Jeff Reuben
Your site isn't serving a cert that covers that name.
See: SSL Server Test: hprauto.com (Powered by Qualys SSL Labs)
And please show the outputs of:
certbot certificates
sudo apachectl -t -D DUMP_VHOSTS
Thank you for your quick response. Here is the output of the two commands:
Renewal configuration file /etc/letsencrypt/renewal/www.classicautoserv.com.conf produced an unexpected error: expected /etc/letsencrypt/live/www.classicautoserv.com/cert.pem to be a symlink. Skipping.
Found the following certs:
Certificate Name: hprauto.com
Serial Number: 4fbcf6d43e117139286b26873e950fc0370
Key Type: RSA
Domains: hprauto.com
Expiry Date: 2022-02-03 21:20:52+00:00 (VALID: 87 days)
Certificate Path: /etc/letsencrypt/live/hprauto.com/fullchain.pem
Private Key Path: /etc/letsencrypt/live/hprauto.com/privkey.pem
Certificate Name: nmis.com
Serial Number: 356c9dc62b16c3f62a97f9a94facb669d75
Key Type: RSA
Domains: nmis.com www.nmis.com
Expiry Date: 2022-01-29 17:51:28+00:00 (VALID: 82 days)
Certificate Path: /etc/letsencrypt/live/nmis.com/fullchain.pem
Private Key Path: /etc/letsencrypt/live/nmis.com/privkey.pem
The following renewal configurations were invalid:
AH00526: Syntax error on line 152 of /private/etc/apache2/extra/httpd-ssl.conf:
SSLCertificateKeyFile: file '/etc/letsencrypt/live/hprauto.com/privkey.pem' does not exist or is empty
That looks like you might have tried to copy some files around and overwrote it.
One should never need to copy any files into the /etc/letsencrypt/ path.
This also points towards a copy gone bad and overwrote a key file.
At this point I can't be sure of what is the best way out of this mess.
One path might be to remove the entire /etc/letsencrypt/ path and reissue your LE certs.
But you would have to review all your steps / scripts to ensure you won't be making this same mistake.
