Apache HTTPS Certbot LetsEncrypt issue
My domain is: mailer9.com
It produced this output: Successful
My web server is (include version): Apache 2.4.29
The operating system my web server runs on is (include version): Ubuntu 18.04 LTS
My hosting provider, if applicable, is: Linode
I am trying to set up a website with HTTPS on a Linode server. It’s working on HTTP but not on HTTPS.
I tried to use Certbot to configure my domain for HTTPS.
root@mailer9:/etc/apache2/sites-enabled# sudo certbot --apache
1: mailer9.com
2: www.mailer9.com
Attempting to parse the version 0.29.1 renewal configuration file found at /etc/letsencrypt/renewal/mailer9.com.conf with version 0.28.0 of Certbot. This might not work.
Cert not yet due for renewal
(ref: /etc/letsencrypt/renewal/mailer9.com.conf)
What would you like to do?
http-01 challenge for mailer9.com
http-01 challenge for www.mailer9.com
Deploying Certificate to VirtualHost /etc/apache2/sites-enabled/mailer9.com-le-ssl.conf
new sites, or if you're confident your site works on HTTPS. You can undo this
change by editing your web server's configuration.
Your existing certificate has been successfully renewed, and the new certificate
has been installed.
The new certificate covers the following domains: https://mailer9.com and
https://www.mailer9.com
https://www.ssllabs.com/ssltest/analyze.html?d=mailer9.com
https://www.ssllabs.com/ssltest/analyze.html?d=www.mailer9.com
   /etc/letsencrypt/live/mailer9.com/fullchain.pem
   /etc/letsencrypt/live/mailer9.com/privkey.pem
   Your cert will expire on 2019-04-02. To obtain a new or tweaked
   with the "certonly" option. To non-interactively renew *all* of
   Donating to ISRG / Let's Encrypt:   https://letsencrypt.org/donate
   Donating to EFF:                    https://eff.org/donate-le
It says that thing should be working fine but it’s not working in HTTPS mode.
I see two VH files in sites-enabled directory.
root@mailer9:/etc/apache2/sites-enabled# cat mailer9.com.conf
# domain: mailer9.com
# public: /var/www/html/mailer9.com/public_html/
<VirtualHost *:80>
  # Admin email, Server Name (domain name), and any aliases
  ServerAdmin xxx@yy.com
  ServerName  mailer9.com
  ServerAlias www.mailer9.com
  # Index file and Document Root (where the public files are located)
  DirectoryIndex index.html index.php
  DocumentRoot /var/www/html/mailer9.com/public_html
  # Log file locations
  LogLevel warn
  ErrorLog  /var/www/html/mailer9.com/log/error.log
  CustomLog /var/www/html/mailer9.com/log/access.log combined
#RewriteEngine on
#RewriteCond %{SERVER_NAME} =mailer9.com [OR]
#RewriteCond %{SERVER_NAME} =www.mailer9.com
#RewriteRule ^ https://%{SERVER_NAME}%{REQUEST_URI} [END,NE,R=permanent]
</VirtualHost>
Another one for HTTPS, auto-generated by Certbot.
root@mailer9:/etc/apache2/sites-enabled# cat mailer9.com-le-ssl.conf
<IfModule mod_ssl.c>
<VirtualHost *:443>
  LogLevel warn
SSLEngine on
SSLCertificateFile /etc/letsencrypt/live/mailer9.com/fullchain.pem
SSLCertificateKeyFile /etc/letsencrypt/live/mailer9.com/privkey.pem
</VirtualHost>
</IfModule>
However, if I visit http://mailer9.com/ then it works fine. But if I go to https://mailer9.com/ the page doesn’t load. I am clueless about how to solve it, everything looks fine to me.
Apache modules command apachectl -M shows ssl_module is loaded.
Hi @JournalDev
yep, there are two timeouts:
http://mailer9.com/
23.92.25.161 200 0.344 H
http://www.mailer9.com/
23.92.25.161 200 0.346 H
23.92.25.161 -14 10.047 T
Timeout - The operation has timed out
https://www.mailer9.com/
23.92.25.161 -14 10.026 T
But your certificate exists.
https://transparencyreport.google.com/https/certificates?cert_search_auth=&cert_search_cert=&cert_search=include_expired:false;include_subdomains:false;domain:mailer9.com&lu=cert_search
Is there a firewall? Or a wrong router forwarding?
Yes, it was causing because of ufw firewall. I allowed 443 port by following commands and it started working fine.
sudo ufw allow 443/tcp
Thanks for your input regarding firewall, it helped me in fixing this.
