WordPress 4.7.2, running on Apache 2.4.23 :
Bitnami Wordpress Lightsail
Linux 3.13 generic
Was it installed as the root user?
Lightsail Bitnami wordpress installation
Is there anything you’ve done and/or tried with the application before posting here?
No
E.g. changed permissions or installed a plugin:
Used lightsail to launch a wordpress server, then went to this tutorial:
https://docs.bitnami.com/aws/components/apache/#how-to-install-the-lets-encrypt-client2
The letsencrypt cerbot tutorial is straight forward, until apache restart.
I am now getting an error on apache restart:
httpd could not be started
My httpd-vhosts.conf original file:
<VirtualHost *:80>
ServerName wordpress.example.com
ServerAlias www.wordpress.example.com
DocumentRoot "/opt/bitnami/apps/wordpress/htdocs"
Include "/opt/bitnami/apps/wordpress/conf/httpd-app.conf"
</VirtualHost>
<VirtualHost *:443>
SSLEngine on
SSLCertificateFile "/opt/bitnami/apps/wordpress/conf/certs/server.crt"
SSLCertificateKeyFile "/opt/bitnami/apps/wordpress/conf/certs/server.key"
</VirtualHost>
My httpd-vhosts.conf edited file:
<VirtualHost *:80>
ServerName 54.xx.xxx.xxx (PUBLIC_IP)
ServerAlias www.MyDomain.com
</VirtualHost>
<VirtualHost *:443>
ServerAlias www;MyDomain.com
SSLEngine on
SSLCertificateFile "/opt/bitnami/apache2/conf/server.crt"
SSLCertificateKeyFile "opt/bitnami/apache2/conf/certs/server.key"
</VirtualHost>
I’ve pointed the pem and keys to where the bitnami letsencrypt tutorial says to copy the certs over to:
Below is an apache2 error log report:
[Thu Feb 09 22:13:00.165679 2017] [ssl:error] [pid 1740:tid 140302623450944] AH02579: Init: Private key not found
[Thu Feb 09 22:13:00.165725 2017] [ssl:error] [pid 1740:tid 140302623450944] SSL Library Error: error:0D0680A8:asn1 encoding routines:ASN1_CHECK_TLEN:wrong tag
[Thu Feb 09 22:13:00.165739 2017] [ssl:error] [pid 1740:tid 140302623450944] SSL Library Error: error:0D08303A:asn1 encoding routines:ASN1_TEMPLATE_NOEXP_D2I:nested asn1 error
[Thu Feb 09 22:13:00.165762 2017] [ssl:error] [pid 1740:tid 140302623450944] SSL Library Error: error:0D0680A8:asn1 encoding routines:ASN1_CHECK_TLEN:wrong tag
[Thu Feb 09 22:13:00.165783 2017] [ssl:error] [pid 1740:tid 140302623450944] SSL Library Error: error:0D07803A:asn1 encoding routines:ASN1_ITEM_EX_D2I:nested asn1 error (Type=RSA)
[Thu Feb 09 22:13:00.165806 2017] [ssl:error] [pid 1740:tid 140302623450944] SSL Library Error: error:04093004:rsa routines:OLD_RSA_PRIV_DECODE:RSA lib
[Thu Feb 09 22:13:00.165816 2017] [ssl:error] [pid 1740:tid 140302623450944] SSL Library Error: error:0D0680A8:asn1 encoding routines:ASN1_CHECK_TLEN:wrong tag
[Thu Feb 09 22:13:00.165826 2017] [ssl:error] [pid 1740:tid 140302623450944] SSL Library Error: error:0D07803A:asn1 encoding routines:ASN1_ITEM_EX_D2I:nested asn1 error (Type=PKCS8_PRIV_KEY_INFO)
[Thu Feb 09 22:13:00.165830 2017] [ssl:emerg] [pid 1740:tid 140302623450944] AH02312: Fatal error initialising mod_ssl, exiting.
[Thu Feb 09 22:13:00.165833 2017] [ssl:emerg] [pid 1740:tid 140302623450944] AH02564: Failed to configure encrypted (?) private key localhost:443:0, check /opt/bitnami/apache2/conf/server.key
AH00016: Configuration Failed
My assumption is it;s the above file that is preventing httpd to start sine it needs to validate the letsencrypt certs to preform https.
Any help is greatly appreciated.
