./letsencrypt-auto failed due to hash problems
I try to install letsencrypt on my system, but while installing it brings an error when installing Python:
Bootstrapping dependencies for Debian-based OSes… (you can skip this with --no-bootstrap)
Hit:1 http://raspbian.raspberrypi.org/raspbian buster InRelease
Hit:2 http://archive.raspberrypi.org/debian buster InRelease
Reading package lists… Done
Building dependency tree
Reading state information… Done
augeas-lenses is already the newest version (1.11.0-3).
ca-certificates is already the newest version (20190110).
gcc is already the newest version (4:8.3.0-1+rpi2).
libaugeas0 is already the newest version (1.11.0-3).
libffi-dev is already the newest version (3.2.1-9).
libssl-dev is already the newest version (1.1.1d-0+deb10u2).
openssl is already the newest version (1.1.1d-0+deb10u2).
python is already the newest version (2.7.16-1).
python-dev is already the newest version (2.7.16-1).
python-virtualenv is already the newest version (15.1.0+ds-2).
0 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
Creating virtual environment…
Installing Python packages…
Had a problem while installing Python packages.
pip prints the following errors:
Collecting ConfigArgParse==0.14.0 (from -r /tmp/tmp.K1GW7bKPY2/letsencrypt-auto-requirements.txt (line 12))
…SNIP/SNAP due to 20 links limitation
https://files.pythonhosted.org/packages/70/cb/cbae8fcccbf613fc65f817fccceefd5370d911e186d604c8657e2bab16df/certbot_apache-1.0.0-py2.py3-none-any.whl (68kB)
Collecting certbot-nginx==1.0.0 (from -r /tmp/tmp.K1GW7bKPY2/letsencrypt-auto-requirements.txt (line 250))
Downloading https://files.pythonhosted.org/packages/f8/b2/5e79c2b8b4dbaa1dc060388cd47e710013e43578394cce5b727152752f54/certbot_nginx-1.0.0-py2.py3-none-any.whl (45kB)
Requirement already satisfied: setuptools>=1.0 in /opt/eff.org/certbot/venv/lib/python2.7/site-packages (from josepy==1.2.0->-r /tmp/tmp.K1GW7bKPY2/letsencrypt-auto-requirements.txt (line 97))
THESE PACKAGES DO NOT MATCH THE HASHES FROM THE REQUIREMENTS FILE. If you have updated the package versions, please update the hashes. Otherwise, examine the package contents carefully; someone may have tampered with them.
pycparser==2.19 from https://www.piwheels.org/simple/pycparser/pycparser-2.19-py2.py3-none-any.whl#sha256=bc15573b7c6edd24407526dbbc7a0bd33d80d8af44231c37f58d73f56ff9cab6 (from -r /tmp/tmp.K1GW7bKPY2/letsencrypt-auto-requirements.txt (line 115)):
Expected sha256 a988718abfad80b6b157acce7bf130a30876d27603738ac39f140993246b25b3
Got bc15573b7c6edd24407526dbbc7a0bd33d80d8af44231c37f58d73f56ff9cab6
zope.component==4.6 from https://www.piwheels.org/simple/zope-component/zope.component-4.6-py2.py3-none-any.whl#sha256=74f55521dec189c08d98341edce929eba6bb2404662d1878f1b289af46f6f6a5 (from -r /tmp/tmp.K1GW7bKPY2/letsencrypt-auto-requirements.txt (line 137)):
    Expected sha256 ec2afc5bbe611dcace98bb39822c122d44743d635dafc7315b9aef25097db9e6
         Got        74f55521dec189c08d98341edce929eba6bb2404662d1878f1b289af46f6f6a5
Certbot has problem setting up the virtual environment.
We were not be able to guess the right solution from your pip
output.
Consult https://certbot.eff.org/docs/install.html#problems-with-python-virtual-environment
for possible solutions.
You may also find some support resources at https://certbot.eff.org/support/
maybe someone of you can help me
For Raspbian Buster, it’s recommended you just install Certbot from your package manager:
apt install certbot
If you want to continue to use Certbot via letsencrypt-auto, there is a workaround documented in this post: Certbot-auto certificates fails while installing phyton packages with THESE PACKAGES DO NOT MATCH THE HASHES
