If you find dns-01 complicated, the easy solution is to switch ISP.
dns-01 isn't actually complicated, but you need to find the right certbot plugin for your DNS provider. Also, your DNS provider and your domain registrar can be different companies, so, let's say you registered your domain on GoDaddy: nothing is preventing you from using cloudflare as authoritative DNS.
Hi, I know you said not to run with this method but I just want to get SSL installed on my server. The installation seemed to go OK and I seem to have everything installed OK:
pi@raspberrypi:~ $ sudo ls -l /etc/letsencrypt/live/footiefantasy.eu
total 4
lrwxrwxrwx 1 root root 40 Aug 7 11:00 cert.pem -> ../../archive/footiefantasy.eu/cert1.pem
lrwxrwxrwx 1 root root 41 Aug 7 11:00 chain.pem -> ../../archive/footiefantasy.eu/chain1.pem
lrwxrwxrwx 1 root root 45 Aug 7 11:00 fullchain.pem -> ../../archive/footiefantasy.eu/fullchain1.pem
lrwxrwxrwx 1 root root 43 Aug 7 11:00 privkey.pem -> ../../archive/footiefantasy.eu/privkey1.pem
-rw-r--r-- 1 root root 692 Aug 7 11:00 README
I installed the TXT and the _acme-challenge:
Please, in the future, if you say "it's not working" please specify WHAT's not working. Error messages? Screenshots? Exact behaviour leading to the error? Et cetera.
Hi, Sorry. I meant that I thought after doing this installation and getting the letsencrypt certificates that the security lock icon associated with HTTPS would appear on my footiefantasy.eu website. Currently, it says not secure.?
Hi, do I have to create another certificate for the _acme-challenge.www or use the same certificate as the _acme-challenge ?. Thank you for your help...
Hi, I thought after doing this installation and getting the letsencrypt certificates that the security lock icon associated with HTTPS would appear on my footiefantasy.eu website. Currently, it says not secure.? Do I have to do anything more or should it appear automatically (I have restarted apache2 server). I tried running it again and got this which seems to prove that it installed correctly:
sudo certbot --manual --preferred-challenges dns certonly -d footiefantasy.eu
(ref: /etc/letsencrypt/renewal/footiefantasy.eu.conf)
What would you like to do?
1: Keep the existing certificate for now
2: Renew & replace the certificate (may be subject to CA rate limits)
Select the appropriate number [1-2] then [enter] (press 'c' to cancel):
Sorry to keep asking all these questions but I really want to get the HTTPS working on my site. Many Thanks...
Which certificate would you like to install?
1: footiefantasy.eu
Press 1 [enter] to confirm the selection (press 'c' to cancel): 1
Deploying certificate
Successfully deployed certificate for footiefantasy.eu to /etc/apache2/sites-available/000-default-le-ssl.conf
HELPPPPPPPPP, I did that and now the website doesnt work at all now!!! Port 443 is closed so I cant understand why its saying
IfModule mod_ssl.c
VirtualHost *:443
# specifies what hostname must appear in the request's Host: header to
#ServerName www.example.com
DocumentRoot /var/www/html
ServerName footiefantasy.eu
ServerAlias www.footiefantasy.eu
# error, crit, alert, emerg.
# modules, e.g.
#LogLevel info ssl:warn
# the two lines below I think are to do with modsecurity which I have disabled
# so that I can try and setup a SSL certificate.
# SecRuleEngine On
# SecRule ARGS:testparam "@contains test" "id:999,deny,status:403,msg:'Test Successful'"
SSLCertificateFile /etc/letsencrypt/live/footiefantasy.eu/fullchain.pem
SSLCertificateKeyFile /etc/letsencrypt/live/footiefantasy.eu/privkey.pem
</VirtualHost>
</IfModule>
