Lets Encrypt issue incorrect, too many certs
Im using inmotion hosting
I have been having problems getting Let Encrypt SSL certificates. The message has been that there has been too many issued, over use of some sort. I have 80 sites in one cpanel. In looking further I found that
  1. the certs are jumbled, multiple names and combination of names on one cert
  2. Let's Encrypt has over 1,300 Certificates issued because of the above
Please see examples below: Doing a search for 'Cert for " "daystarmotors' Shows currently 19 separate SSL certificates.
Here are a couple daystarmotors certs:
1)Note autotech is jumbled in to here
cpanel.autotech-miami.com
cpanel.daystarmotors.us
cpcalendars.autotech-miami.com
cpcalendars.daystarmotors.us
cpcontacts.autotech-miami.com
cpcontacts.daystarmotors.us
webdisk.autotech-miami.com
webdisk.daystarmotors.us
webmail.autotech-miami.com
webmail.daystarmotors.us
whm.autotech-miami.com
whm.daystarmotors.us
www.autotech-miami.com
www.autotech-miami.drozconsultinggroup.com
www.daystarmotors.drozconsultinggroup.com
www.daystarmotors.us
  1. Note abauto and wontgo are jumbled in to here
cpanel.abautomotiveservices.com
cpcalendars.abautomotiveservices.com
cpcontacts.abautomotiveservices.com
webdisk.abautomotiveservices.com
webmail.abautomotiveservices.com
whm.abautomotiveservices.com
www.abautomotiveservices.com
www.abautomotiveservices.drozconsultinggroup.com
www.wontgocallro.drozconsultinggroup.com
  1. Note: Trucksport is jumbled in to here
cpanel.trucksportamerica.org
cpcalendars.trucksportamerica.org
cpcontacts.trucksportamerica.org
mail.trucksportamerica.org
trucksportamerica.drozconsultinggroup.com
webdisk.trucksportamerica.org
webmail.trucksportamerica.org
whm.trucksportamerica.org
www.trucksportamerica.drozconsultinggroup.com
www.trucksportamerica.org Let's Encrypt 6/27/22 2048 Cert for “daystarmotors.drozconsultinggroup.com” 1648568989.0 Let's Encrypt 6/13/22 2048 Cert for “daystarmotors.drozconsultinggroup.com” 1647370128.0 Let's Encrypt 6/24/22 2048 Cert for “daystarmotors.drozconsultinggroup.com” 1648266540.0
Hi @tomDroz, and welcome to the LE community forum :slight_smile:
LE only issues certs that have been requested and have been validated.
The problem you are showing (if that is indeed an actual problem) can only be caused by the ACME client that is making the certificate requests.
So, you need to speak with whomever is in control of that ACME client (or that server) about your concerns.
Thank you, i just tried to add a new site and here is the actual error:
2:00:50 PM WARN AutoSSL failed to create a new certificate order because the server’s Let’s Encrypt account (https://acme-v01.api.letsencrypt.org/acme/reg/10811467) has reached a rate limit. (429 urn:ietf:params:acme:error:rateLimited (The request exceeds a rate limit) (Error creating new order :: too many certificates already issued for: drozconsultinggroup.com: see Rate Limits - Let's Encrypt)) You may contact Let’s Encrypt to request a change to this rate limit.
ERROR “Let’s Encrypt™” general error (conklinautosalesny.com): A rate limit prevents DCV.
ERROR “Let’s Encrypt™” general error (www.conklinautosalesny.com): A rate limit prevents DCV.
ERROR “Let’s Encrypt™” general error (mail.conklinautosalesny.com): A rate limit prevents DCV.
ERROR “Let’s Encrypt™” general error (webmail.conklinautosalesny.com): A rate limit prevents DCV.
ERROR “Let’s Encrypt™” general error (cpanel.conklinautosalesny.com): A rate limit prevents DCV.
ERROR “Let’s Encrypt™” general error (whm.conklinautosalesny.com): A rate limit prevents DCV.
ERROR “Let’s Encrypt™” general error (webdisk.conklinautosalesny.com): A rate limit prevents DCV.
ERROR “Let’s Encrypt™” general error (cpcontacts.conklinautosalesny.com): A rate limit prevents DCV.
ERROR “Let’s Encrypt™” general error (cpcalendars.conklinautosalesny.com): A rate limit prevents DCV.
ERROR “Let’s Encrypt™” general error (conklinautosalesny.drozconsultinggroup.com): A rate limit prevents DCV.
ERROR “Let’s Encrypt™” general error (www.conklinautosalesny.drozconsultinggroup.com): A rate limit prevents DCV.
ERROR Impediment: TOTAL_DCV_FAILURE: Every domain failed DCV.
Again:
That error is due to too many requests and too many certs already having been issued.
