I am currently facing a strange issue regarding how let’s encrypt and nginx work together.
I have successfully installed the certificates on my website and everything works well at this moment.
However I decided to update some changes to my nginx.conf file and on my surprise, when I restarted nginx the changes were not applied. So I tried to look if there was another nginx config file being used and it seems that let’s encrypt keeps a backups/ folder with the old nginx.conf contents I had before making those changes. Looks like my nginx is serving that file instead of the one he should be (/usr/local/etc/nginx/nginx.conf => returned from the command “nginx -t”)
So the question is: Is there a way to remove the cache of let’s encrypt ?
Are you running FreeBSD or Darwin? If so, it might explain why certbot uses /usr/local/etc/nginx/ as root directory of nginx. Those directories, depending on your *nix variant, are hardcoded in the nginx plugin:
I’m not sure about every aspect of the code however:
Luckily, you can override this server-root variable on the command line:
If you run certbot --help, it should confirm the erroneous server root as the default option listed under the server-root option.
By setting --server-root to the correct directory, it might prevent this from happening again.
You also might want to file a bug on github for the certbot team with as much information possible.
