Let's Encrypt and deso-node running in docker-compose
My domain is: node.stakingwallet.com
I ran this command: docker-compose -f docker-compose.dev.yml start nginx
nginx: [emerg] open() "/etc/letsencrypt/options-ssl-nginx.conf" failed (2: No such file or directory) in /etc/nginx/nginx.conf:21
My web server is (include version): nginx/1.18.0
The operating system my web server runs on is (include version): Linux Minx (Ubuntu)
The version of my client is (e.g. output of certbot --version or certbot-auto --version if you're using Certbot):certbot 2.5.0
This is what happens when I try to run the container. I have a nginx.dev file as conf setup in the same path as my .yml file. I upload the content of both files.
Regards.
docker-compose.dev.txt (691 Bytes)
nginx.txt (486 Bytes)
Hi @manolius148, and welcome to the LE community forum :slight_smile:
Are you following some guide/instructions?
Has this [ever] worked before?
To me, it looks like nginx has no access to the /etc/letsencrypt/ folder.
Thank you for the reply.
I'm just trying to run it. I followed the certbot setup instructions to successfully install the certificates. But the docker nginx is unable to effectively run the service, so the site is offline. And no, it has never worked.
Regards.
From within docker?
From the website
(assuming you mean your website)
Is within docker, correct?
What I am trying to say is you are using instructions like these Certbot Instructions | Certbot within docker, so they being executed at the same level of the system as your webserver.
Correct, instructions from certbox website I mean. The problem is when running the container.
So you ran those instructions within the container?
Not outside the container, correct?
I tried both. Anyway the git has a nginx.dev file used by the container as config. Sometimes it gets in conflict to nginx service and I must stop it in order to release 443 port
In fact first of all I installed certbot and got the certificate files inside "letsencrypt/live" with no issues. The problem is when running the nginx service in docker, it always halts (if nginx was previously up, because of the busy 443 port) otherwise it displays the lacking file error.
The outcome is that the certificate is not running in the website.
that'd you are not mounting right dir as volume to nginx container
I can't understand you. I run a script which is in fact a docker-compose service with three containers (backend, frontend and nginx). Nginx docker process uses the nginx.dev file I uploaded earlier to set the params.
add somthing like /etc/letsencrypt:/etc/letsencrypt nginx's docker-compose volume (not bother which side is which nor symlink thing) and looks file from nginx config. it cant' read cert if dir is not mount
?? can't understand your reply
volumes:
  - ./nginx.dev:/etc/nginx/nginx.conf
  - /etc/letsencrypt:/etc/letsencrypt
Ahm ok I will try thank you
Selection_001
Solved!! Tahnk you so much!
My acknwoledgement:
before you leave, it may need nginx reload to detect updated certificate after renewal after 60 days:
