What is strange is that the next command that ran in the script worked just fine and generate the script for the next domain needed.
2021-10-27 11:03:47,354:DEBUG:certbot._internal.main:Location of certbot entry point: /snap/certbot/1514/bin/certbot
2021-10-27 11:03:47,354:DEBUG:certbot._internal.main:Arguments: ['--webroot', '-w', '/var/www/wkweiea9ixstat.mgddns.io/htdocs', '--cert-name', 'wkweiea9ixstat.mgddns.io', '-d', 'wkweiea9ixstat.mgddns.io', '--email', 'hostservices@mgdwp.com', '--no-eff-email', '--agree-tos', '--staple-ocsp', '--must-staple', '--preferred-chain', 'ISRG Root X1', '--preconfigured-renewal']
2021-10-27 11:03:47,354:DEBUG:certbot._internal.main:Discovered plugins: PluginsRegistry(PluginEntryPoint#apache,PluginEntryPoint#manual,PluginEntryPoint#nginx,PluginEntryPoint#null,PluginEntryPoint#standalone,PluginEntryPoint#webroot)
2021-10-27 11:03:47,373:DEBUG:certbot._internal.log:Root logging level set at 30
2021-10-27 11:03:47,374:DEBUG:certbot._internal.plugins.selection:Requested authenticator webroot and installer None
2021-10-27 11:03:47,379:DEBUG:certbot._internal.plugins.selection:Single candidate plugin: * webroot
Description: Place files in webroot directory
Interfaces: Authenticator, Plugin
Entry point: webroot = certbot._internal.plugins.webroot:Authenticator
Initialized: <certbot._internal.plugins.webroot.Authenticator object at 0x7fd5d2cebb80>
Prep: True
2021-10-27 11:03:47,380:DEBUG:certbot._internal.plugins.selection:Selected authenticator <certbot._internal.plugins.webroot.Authenticator object at 0x7fd5d2cebb80> and installer None
2021-10-27 11:03:47,380:INFO:certbot._internal.plugins.selection:Plugins selected: Authenticator webroot, Installer None
2021-10-27 11:03:47,389:DEBUG:certbot._internal.main:Picked account: <Account(RegistrationResource(body=Registration(key=None, contact=(), agreement=None, status=None, terms_of_service_agreed=None, only_return_existing=None, external_account_binding=None), uri='https://acme-v02.api.letsencrypt.org/acme/acct/256890810', new_authzr_uri=None, terms_of_service=None), 563eea62195134f2517cdee7f18ce9f1, Meta(creation_dt=datetime.datetime(2021, 10, 27, 10, 57, 36, tzinfo=<UTC>), creation_host='localhost', register_to_eff=None))>
2021-10-27 11:03:47,390:DEBUG:acme.client:Sending GET request to https://acme-v02.api.letsencrypt.org/directory.
2021-10-27 11:03:47,393:DEBUG:urllib3.connectionpool:Starting new HTTPS connection (1): acme-v02.api.letsencrypt.org:443
2021-10-27 11:04:02,591:DEBUG:certbot._internal.log:Exiting abnormally:
File "/snap/certbot/1514/lib/python3.8/site-packages/urllib3/connectionpool.py", line 699, in urlopen
httplib_response = self._make_request(
File "/snap/certbot/1514/lib/python3.8/site-packages/urllib3/connectionpool.py", line 382, in _make_request
self._validate_conn(conn)
File "/snap/certbot/1514/lib/python3.8/site-packages/urllib3/connectionpool.py", line 1010, in _validate_conn
conn.connect()
File "/snap/certbot/1514/lib/python3.8/site-packages/urllib3/connection.py", line 411, in connect
self.sock = ssl_wrap_socket(
File "/snap/certbot/1514/lib/python3.8/site-packages/urllib3/util/ssl_.py", line 449, in ssl_wrap_socket
ssl_sock = _ssl_wrap_socket_impl(
File "/snap/certbot/1514/lib/python3.8/site-packages/urllib3/util/ssl_.py", line 493, in _ssl_wrap_socket_impl
return ssl_context.wrap_socket(sock, server_hostname=server_hostname)
File "/snap/certbot/1514/usr/lib/python3.8/ssl.py", line 500, in wrap_socket
return self.sslsocket_class._create(
File "/snap/certbot/1514/usr/lib/python3.8/ssl.py", line 1040, in _create
self.do_handshake()
File "/snap/certbot/1514/usr/lib/python3.8/ssl.py", line 1309, in do_handshake
self._sslobj.do_handshake()
ConnectionResetError: [Errno 104] Connection reset by peer
File "/snap/certbot/1514/lib/python3.8/site-packages/requests/adapters.py", line 439, in send
resp = conn.urlopen(
File "/snap/certbot/1514/lib/python3.8/site-packages/urllib3/connectionpool.py", line 755, in urlopen
retries = retries.increment(
File "/snap/certbot/1514/lib/python3.8/site-packages/urllib3/util/retry.py", line 532, in increment
raise six.reraise(type(error), error, _stacktrace)
File "/snap/certbot/1514/lib/python3.8/site-packages/urllib3/packages/six.py", line 769, in reraise
raise value.with_traceback(tb)
conn.connect()
self.do_handshake()
urllib3.exceptions.ProtocolError: ('Connection aborted.', ConnectionResetError(104, 'Connection reset by peer'))
File "/snap/certbot/1514/bin/certbot", line 8, in <module>
sys.exit(main())
File "/snap/certbot/1514/lib/python3.8/site-packages/certbot/main.py", line 15, in main
File "/snap/certbot/1514/lib/python3.8/site-packages/certbot/_internal/main.py", line 1574, in main
File "/snap/certbot/1514/lib/python3.8/site-packages/certbot/_internal/main.py", line 1416, in certonly
le_client = _init_le_client(config, auth, installer)
File "/snap/certbot/1514/lib/python3.8/site-packages/certbot/_internal/main.py", line 770, in _init_le_client
return client.Client(config, acc, authenticator, installer, acme=acme)
File "/snap/certbot/1514/lib/python3.8/site-packages/certbot/_internal/client.py", line 262, in __init__
acme = acme_from_config_key(config, self.account.key, self.account.regr)
File "/snap/certbot/1514/lib/python3.8/site-packages/certbot/_internal/client.py", line 44, in acme_from_config_key
client = acme_client.BackwardsCompatibleClientV2(net, key, config.server)
File "/snap/certbot/1514/lib/python3.8/site-packages/acme/client.py", line 840, in __init__
directory = messages.Directory.from_json(net.get(server).json())
File "/snap/certbot/1514/lib/python3.8/site-packages/acme/client.py", line 1194, in get
self._send_request('GET', url, **kwargs), content_type=content_type)
File "/snap/certbot/1514/lib/python3.8/site-packages/acme/client.py", line 1133, in _send_request
response = self.session.request(method, url, *args, **kwargs)
File "/snap/certbot/1514/lib/python3.8/site-packages/requests/sessions.py", line 542, in request
resp = self.send(prep, **send_kwargs)
File "/snap/certbot/1514/lib/python3.8/site-packages/requests/sessions.py", line 655, in send
r = adapter.send(request, **kwargs)
File "/snap/certbot/1514/lib/python3.8/site-packages/requests/adapters.py", line 498, in send
raise ConnectionError(err, request=request)
requests.exceptions.ConnectionError: ('Connection aborted.', ConnectionResetError(104, 'Connection reset by peer'))
2021-10-27 11:04:02,603:ERROR:certbot._internal.log:An unexpected error occurred:
2021-10-27 11:04:02,604:ERROR:certbot._internal.log:requests.exceptions.ConnectionError: ('Connection aborted.', ConnectionResetError(104, 'Connection reset by peer'))
nginx version: nginx/1.16.1
Ubuntu 20.04.3 LTS
Private cloud
certbot 1.20.0
