LDNS error - when renewing certficates with getssl
My domain is:pfeiffer-koberstein-immobilien.de
I ran this command for renewing the certificates:
getssl pfeiffer-koberstein-immobilien.de -w /pathworkingdirectory/.getssl -a
Error: error sending query: General LDNS error
apache 2.4.7 ubuntu
Linux ubuntu 14.04 lts, remote-system, place of the certificates
archlinux 5.10-lts, local system, where getssl ist running, for renewing and sending to remote-system
Info: the certificates were generated with ubuntu 16.04, getssl running system
Strato, root-server
The version of my client is (e.g. output of certbot --version or certbot-auto --version if you're using Certbot): getssl 2.36, latest version on GitHub - srvrco/getssl: obtain free SSL certificates from letsencrypt ACME server Suitable for automating the process on remote servers.
That looks like an error getssl is having with the DNS library it uses. That is better addressed to the developer of getssl at GitHub - srvrco/getssl: obtain free SSL certificates from letsencrypt ACME server Suitable for automating the process on remote servers.
Hi @iksmax
I'm one of the maintainers of getssl. I've not seen that error before, but I've not use the ldns library or archlinux.
Can you run getssl with the -d debug option and either post the output here or on github - I think drill is returning an error and with the debug output I should be able to track down the problem.
@iksmax
Does DNS work on your system/server?
Hi timkimber,
thanks for your answer. Here's the -d -output:
detected os type = linux
Running \e[01;31m ========= \e[01;37mSystemRescue 8.05 (x86_64)\e[01;31m ======== \e[01;37m\l\e[00;37m/6\e[01;31m =========
\e[00;31mhttps://www.system-rescue.org/
\e[00;31m*\e[01;31m Console environment\e[00;37m :
Run \e[01;37msetkmap\e[00;37m to choose the keyboard layout
\e[00;31m*\e[01;31m Graphical environment\e[00;37m :
Type \e[01;37mstartx\e[00;37m to run the graphical environment
X.Org comes with the XFCE environment and several graphical tools:
\e[00;31m-\e[00;37m Partition manager: .. \e[01;37mgparted\e[00;37m
\e[00;31m-\e[00;37m Web browser: ........ \e[01;37mfirefox\e[00;37m
\e[00;31m-\e[00;37m Text editor: ........ \e[01;37mfeatherpad\e[00;37m
checking for required which ... /usr/bin/which
checking for required openssl ... /usr/bin/openssl
checking for required curl ... /usr/bin/curl
checking for dig ... /usr/bin/dig
function dig found at /usr/bin/dig - setting DNS_CHECK_FUNC to dig
checking for required dirname ... /usr/bin/dirname
checking for required awk ... /usr/bin/awk
checking for required tr ... /usr/bin/tr
checking for required date ... /usr/bin/date
checking for required grep ... /usr/bin/grep
checking for required sed ... /usr/bin/sed
checking for required sort ... /usr/bin/sort
checking for required mktemp ... /usr/bin/mktemp
Checking for releases at https://api.github.com/repos/srvrco/getssl/releases/latest
{"url":"https://api.github.com/repos/srvrco/getssl/releases/51143195","assets_url":"https://api.github.com/repos/srvrco/getssl/releases/51143195/assets","upload_url":"https://uploads.github.com/repos/srvrco/getssl/releases/51143195/assets{?name,label}","html_url":"https://github.com/srvrco/getssl/releases/tag/v2.45","id":51143195,"author":{"login":"timkimber","id":15785928,"node_id":"MDQ6VXNlcjE1Nzg1OTI4","avatar_url":"https://avatars.githubusercontent.com/u/15785928?v=4","gravatar_id":"","url":"https://api.github.com/users/timkimber","html_url":"https://github.com/timkimber","followers_url":"https://api.github.com/users/timkimber/followers","following_url":"https://api.github.com/users/timkimber/following{/other_user}","gists_url":"https://api.github.com/users/timkimber/gists{/gist_id}","starred_url":"https://api.github.com/users/timkimber/starred{/owner}{/repo}","subscriptions_url":"https://api.github.com/users/timkimber/subscriptions","organizations_url":"https://api.github.com/users/timkimber/orgs","repos_url":"https://api.github.com/users/timkimber/repos","events_url":"https://api.github.com/users/timkimber/events{/privacy}","received_events_url":"https://api.github.com/users/timkimber/received_events","type":"User","site_admin":false},"node_id":"RE_kwDOAvJYls4DDGIb","tag_name":"v2.45","target_commitish":"master","name":"Stable Release 2.45","draft":false,"prerelease":false,"created_at":"2021-10-11T13:31:25Z","published_at":"2021-10-11T13:36:26Z","assets":,"tarball_url":"https://api.github.com/repos/srvrco/getssl/tarball/v2.45","zipball_url":"https://api.github.com/repos/srvrco/getssl/zipball/v2.45","body":"2021-10-08 Extract release tag from release api using awk (#717) (fix BSD issues)\r\n2021-10-11 Fix broken upgrade url (#718)(2.45)"}
current code is version 2.45
Most recent version is 2.45
reading config from /mnt/linux/home/pfeiffer/.getssl/getssl.cfg
checking for required dig ... /usr/bin/dig
Making temp directory - /mnt/linux/home/pfeiffer/.getssl/pfeiffer-koberstein-immobilien.de/tmp
reading config from /mnt/linux/home/pfeiffer/.getssl/pfeiffer-koberstein-immobilien.de/getssl.cfg
HAS NSLOOKUP=true
HAS DIG_OR_DRILL=drill
DIG_SUPPORTS_NOIDNOUT=true
HAS HOST=true
Has lftp
Using certificate issuer: https://acme-staging-v02.api.letsencrypt.org
checking config
checked ACCOUNT_KEY_TYPE
checked PRIVATE_KEY_ALG
checking domain pfeiffer-koberstein-immobilien.de
DNS lookup using drill pfeiffer-koberstein-immobilien.de
DNS lookup using host pfeiffer-koberstein-immobilien.de
DNS lookup using nslookup -query AAAA pfeiffer-koberstein-immobilien.de
found IPv4 record for pfeiffer-koberstein-immobilien.de
checking domain www.pfeiffer-koberstein-immobilien.de
DNS lookup using drill www.pfeiffer-koberstein-immobilien.de
DNS lookup using host www.pfeiffer-koberstein-immobilien.de
DNS lookup using nslookup -query AAAA www.pfeiffer-koberstein-immobilien.de
found IPv4 record for www.pfeiffer-koberstein-immobilien.de
pfeiffer-koberstein-immobilien.de: check_config completed - all OK
ca_all_loc from https://acme-staging-v02.api.letsencrypt.org gives
Boulder: The Let's Encrypt CA
  <div class="col-xs-6 text-left">
    <h1>Boulder<br>
    <small>The Let's Encrypt CA</small></h1>
  </div>
</div>
<div class="row">
  <div class="col-xs-8 col-xs-offset-2 text-center">
    <h3>This is an <a href="https://github.com/letsencrypt/acme-spec/">ACME</a> Certificate Authority running <a href="https://github.com/letsencrypt/boulder">Boulder</a>.</h3>
    <p>This is a <em>programmatic</em> endpoint, an API for a computer to talk to. You should probably be using a specialized client to utilize the service, and not your web browser. See <a href="https://letsencrypt.org/"><tt>https://letsencrypt.org/</tt></a> for help.</p>
    <p>If you're trying to use this service, note that the starting point, <em>the directory</em>, is available at this URL: <a href="https://acme-staging-v02.api.letsencrypt.org/directory"><tt>https://acme-staging-v02.api.letsencrypt.org/directory</a></tt>.</p>
  </div>
</div>
<div class="row">
  <div class="col-xs-4 col-xs-offset-2 text-center">
    <p><a href="https://letsencrypt.status.io" title="Twitter">
      <i class="fa fa-area-chart"></i>
      Service Status (letsencrypt.status.io)
    </a></p>
  </div>
  <div class="col-xs-4 text-center">
    <p><a href="https://twitter.com/letsencrypt" title="Twitter">
      <i class="fa fa-twitter"></i>
      Check with us on Twitter
    </a></p>
  </div>
</div> <!-- row -->
ca_all_loc from https://acme-staging-v02.api.letsencrypt.org/directory gives {
"kFk0pGdmtic": "Adding random entries to the directory",
"keyChange": "https://acme-staging-v02.api.letsencrypt.org/acme/key-change",
"meta": {
"caaIdentities": [
"letsencrypt.org"
"termsOfService": "https://letsencrypt.org/documents/LE-SA-v1.2-November-15-2017.pdf",
"website": "Staging Environment - Let's Encrypt"
"newAccount": "https://acme-staging-v02.api.letsencrypt.org/acme/new-acct",
"newNonce": "https://acme-staging-v02.api.letsencrypt.org/acme/new-nonce",
"newOrder": "https://acme-staging-v02.api.letsencrypt.org/acme/new-order",
"renewalInfo": "https://acme-staging-v02.api.letsencrypt.org/get/draft-aaron-ari/renewalInfo/",
"revokeCert": "https://acme-staging-v02.api.letsencrypt.org/acme/revoke-cert"
Using API v2
getting certificate for pfeiffer-koberstein-immobilien.de from remote server (pfeiffer-koberstein-immobilien.de)
certificate on server is same as the local cert
created SAN list = subjectAltName=DNS:pfeiffer-koberstein-immobilien.de,DNS:www.pfeiffer-koberstein-immobilien.de
certificate /mnt/linux/home/pfeiffer/.getssl/pfeiffer-koberstein-immobilien.de/pfeiffer-koberstein-immobilien.de.crt exists
local cert is valid until Mar 8 15:54:55 2022 GMT
local cert is for domains: pfeiffer-koberstein-immobilien.de,www.pfeiffer-koberstein-immobilien.de
pfeiffer-koberstein-immobilien.de: certificate is valid for more than 30 days (until Mar 8 15:54:55 2022 GMT)
is the same as before
Hi rg305,
yes, the DNS is running,
This may be part of that problem:
yes, this is possible, from ubuntu 16.04/ php 7, the sql-query syntax changes from mysql to mysqli (improved), for php7 there's an mapping extension for theses old queries
Hi @iksmax
getssl successfully updated your certificate - as drill failed with the LDNS error, it used nslookup instead.
I'll reproduce and fix so that the error isn't shown unless there are no working dns utilities available.
I recently added Ubuntu 14 LTS to the automated tests as there are several getssl users still using that version.
Hi @timkimber,
thanks for your help, the certificate were updated successsfully,
I saw in the getssl script, there are serveral alternatives for DNS-Checking,
on https://tools.ietf.org/wg/acme, I tried to open the following link, but it doesn´t work, https://www.fenron.net/~fenner/ietf/deps/viz/acme.pdf. Is this file protected?
It looks like the domain fenron.net no longer exists. I checked the Internet Archive, and it doesn't have a copy of the file.
I've never looked at the working group page before, so I don't know what the visualisation would have shown.
