Keep getting errors
My domain is: jiwon.me
certbot --authenticator webroot --installer apache --webroot-path /home/pi/public_html -d jiwon.me
http-01 challenge for jiwon.me
Using the webroot path /home/pi/public_html for all unmatched domains.
Failed authorization procedure. jiwon.me (http-01): urn:acme:error:connection :: The server could not connect to the client to verify the domain :: Fetching http://jiwon.me/.well-known/acme-challenge/WYD8svcmY7D-ZK_jcWakl9TQ0Sz-spSu9wrfx7nrJW8: Connection refused
   Domain: jiwon.me
   Type:   connection
   Detail: Fetching
   Connection refused
My web server is (include version): Apache/2.4.25 (Raspbian)
The operating system my web server runs on is (include version):Raspbian GNU/Linux 9 (stretch)
My hosting provider, if applicable, is: https://dnszi.com/
I’m trying to get certification with my domain and subdomain, and it keeps getting errors.
I added A records to my dns manage site like below.
  1. jiwon.me / ddns setting (o) / 218.xxx.217.xxx
  2. blog.jiwon.me / ddns setting (o) / 218.xxx.217.xxx (same as 1)
Did I do something wrong with this? And if I run the command with ‘blog.jiwon.me’, it also shows me errors and it’s ‘Type: unauthorized’.
Your server redirects http (port 80) to https (port 443) but on the port 443, reserved for https, your servers answers an http response:
http://jiwon.me:443/.well-known/acme-challenge/WYD8svcmY7D-ZK_jcWakl9TQ0Sz-spSu9wrfx7nrJW8
(note the “:443” to tells the browsers to communicate using http - not https - on the port 443)
So the best guess is in your virtual host : <VirtualHost *:443> some directives are missing, at least SSLEngine on :
https://httpd.apache.org/docs/2.4/en/ssl/ssl_howto.html
Thank you for your answer.
However, I can’t guess what’s my problem is.
You said some directives are missing, but what kinds of directives in my virtual host conf file?
Actually, I fixed the port because I’m using the port forwarding. It works now!
Thank you!! :smiley:
