Its possible create lets cert only point cname www
It is possible to create a certificate only pointing the host name www.meudominio.com.br and meudominio.com.br for hosting, keeping DNS in Registro.br?
É possível criar certificado somente com apontamento de host name www.meudominio.com.br e meudominio.com.br para a hospedagem, mantendo DNS no registro.br?
Hi @eltonhn and welcome to the LE community forum :slight_smile:
I apologize for the use of English in my response.
DNS is generally not part of the problem.
[unless HTTP access is being blocked by your ISP - but yours is OK]
And since both names point to the same IP, YES; it should be easy to get a cert with both names on it.
You would need to install an ACME client and request a cert with both names on it.
Entretanto, a facilidade de fazê-lo depende do ambiente de hospedagem. Por exemplo, se pode instalar aplicações nele.
@eltonhn, qual tipo de ambiente de hospedagem está pensando aqui?
Thank you very much, it was exactly the procedure I performed. Successful result. The host needed to perform a procedure after acme commands. It's on the air, I'll need to renew every 90 days, but it was a very simple solution after a lot of struggle to get these guidelines, because the hosting in this case offers a paid option, and only allows the automated installation of lets at the panel if the DNS is direct at them entirely, not just the hosts. My question is whether I will have any limitation or security problem in not having pointed the DNS fully at them, and just www.meudominio.com.br and meudominio.com.br. Linux shared hosting.
Muito obrigado, foi exatamente o procedimento que eu realizei. Resultado com sucesso. A hospedagem precisou realizar um procedimento após os comandos do acme. Está no ar, precisarei renovar de 90 em 90 dias, mas foi uma solução muito simples depois de muita luta para conseguir essas orientações, pois a hospedagem nesse caso oferece uma opção paga, e só permite a instalação automatizada do lets via painel se o DNS estiver apontado para eles totalmente, não apenas os hosts. Minha dúvida é se vou ter alguma limitação ou problema de segurança em não ter apontado o DNS totalmente para eles, e apenas www.meudominio.com.br e meudominio.com.br. Hospedagem linux compartilhada.
Only your Hosting Service Provider (HSP) can answer that question.
But it is not normal for them to require full DNS control.
They should have a step-by-step how to for you to follow.
