A little help please
My domain is: prs-calarasi.ro
I ran this command: --------
It produced this output: ---------
My web server is (include version): www.prs-calarasi.ro
The operating system my web server runs on is (include version): nginx version: nginx/1.18.0 (Ubuntu)
My hosting provider, if applicable, is: no
The version of my client is (e.g. output of certbot --version or certbot-auto --version if you're using Certbot): certbot 1.21.0
I created the certificate www.prs-calarasi.ro
can I create the prs-calarasi.ro domain in the same certificate?
if yes, what is the order?
because www.prs-calarasi.ro presents the certificate but prs-calarasi.ro does not have the certificate
Existing certs cannot be modified. But, you can get a new cert with both names by just naming both domains in the command. If you had shown your command I could give example.
But, your DNS has those two domains pointing to different servers. You need to fix that first.
The IP of 217.79.185.18 is for an Apache server. The other IP is nginx.
nslookup prs-calarasi.ro
Address: 145.53.227.236
Address: 217.79.185.18
nslookup www.prs-calarasi.ro
Amsterdam, Netherlands
OpenTLD BV 217.79.185.18
145.53.227.236
Paris, France
Online S.A.S. 145.53.227.236
Almeria, Spain
Vodafone Ono S.A. 145.53.227.236
Zizers, Switzerland
Oskar Emmenegger 145.53.227.236
it is fixed from the DNS zone but has not yet propagated everywhere
it's only the nginx server that I need the certificate for
I still don't need the apache one for this domain
the apache one I will issue mail.prs-calarasi.ro but later
You need to check your authoritative DNS because I still see 2 IP addresses for it (Apache and nginx)
See this test site which uses a method similar to the Let's Encrypt Servers which look at your authoritative DNS
https://unboundtest.com/m/A/prs-calarasi.ro/XK7M4HGW
from Holland it looks like this nslookup
Server: 127.0.0.53
Address: 127.0.0.53#53
Non-authoritative answer:
as a rule
but i need only for nginx
nginx only ip 145.53.227.236
apache only 217.79.185.18
www.prs-calarasi.ro to be the same as prs-calarasi.ro
now i removed the apache server
No. You cannot have two different IP's pointing to two different servers (nginx and Apache)
Right now prs-calarasi.ro has those two and www.prs-calarasi.ro has just nginx
If you want apache for some other domain name, you set its IP on that new name not in the apex prs-calarasi.ro
And, the unboundtest uses your authoritative DNS servers so looking up with that method does not depend on where you lookup or the propagation.
Another way:
 dig +noall +answer A prs-calarasi.ro @prs-calarasi.ro
prs-calarasi.ro.        604800  IN      A       145.53.227.236
prs-calarasi.ro.        604800  IN      A       217.79.185.18
dig +noall +answer A www.prs-calarasi.ro @prs-calarasi.ro
www.prs-calarasi.ro.    604800  IN      A       145.53.227.236
ALSO, you have some DNS config issues you should review and correct. See below
https://dnsviz.net/d/prs-calarasi.ro/dnssec/
OK. Now reissue your original command with both domain names. If nginx is configured properly for both names you should get a cert with both names.
but, do review the DNSViz site I linked. Your DNS has some issues
I see someone here
Let's Encrypt does not rely on that kind of propagation as it uses your authoritative DNS. Please research more about how DNS works.
certbot certonly --non-interactive --agree-tos --nginx -m leo@tvnl.eu -d www.prs-calarasi.ro -d prs-calarasi.ro
is this the command to link the two domains?
actually this was my initial question
how can I link the two www and http domains
The Internet can't resolve the authoritative DNS servers correctly:
prs-calarasi.ro nameserver = ns1.tvnl.eu
prs-calarasi.ro nameserver = prs-calarasi.ro
That is the right certbot command.
But you have to fix the DNS issue first.
Yes, that looks good and I would have said so if you had shown the command you used earlier :slight_smile:
But, as both Rudy and I have noted, you still have DNS issues to resolve so that you have a reliable system
Also, using a single authoritative DNS server is NOT a good idea.
no, the configuration is like that
vps static ip 217.79.185.18
two installed domains tvnl.eu and prs-calarasi.ro
on the server with static ip 217.79.185.18 are the mail servers
on servers 145.53.227.236 there are websites and other databases
dns configuration is on vps
ns1.tvnl.eu it is the same with ns.prs-calarasi.ro
Missing command line flag or config entry for this setting:
You have an existing certificate that contains a portion of the domains you requested (ref: /etc/letsencrypt/renewal/www.prs-calarasi.ro.conf)
It contains these names: www.prs-calarasi.ro
You requested these names for the new certificate: www.prs-calarasi.ro, prs-calarasi.ro.
Do you want to expand and replace this existing certificate with the new certificate?
(You can set this with the --expand flag)
Ask for help or search for solutions at https://community.letsencrypt.org.
curious now it works
I mention that I did not make any changes
website www.prs-calarasi.ro is the same as prs-calarasi.ro
both have a certificate
What does this show?
certbot certificates
