Issuing wget cannot fetch certbot-auto
wget https://dl.eff.org/certbot-auto
Resolving dl.eff.org (dl.eff.org)… 151.101.108.201, 2a04:4e42:1a::201
Connecting to dl.eff.org (dl.eff.org)|151.101.108.201|:443… failed: Connection timed out.
Connecting to dl.eff.org (dl.eff.org)|2a04:4e42:1a::201|:443… failed: Network is unreachable.
c6g.12xlarge
Amazon Linux 2
AWS
no
How can I get cerbot-auto downloaded?
Does your networking work at all?
curl -I -m10 https://google.com
curl -I -m10 https://fastly.com
There seems to be no problem with the network connectivity and the Inbound Rules for the EC2 instance allow access from anywhere for both http and https.
Issuing curl -I -m10 https://google.com returns the following:
HTTP/2 301
content-type : text/html; charset=UTF-8
date : Tue, 01 Sep 2020 12:05:59 GMT
expires : Thu, 01 Oct 2020 12:05:59 GMT
cache-control : public, max-age=2592000
server : gws
content-length : 220
x-xss-protection : 0
x-frame-options : SAMEORIGIN
alt-svc : h3-29=":443"; ma=2592000,h3-27=":443"; ma=2592000,h3-T051=":443"; ma=2592000,h3-T050=":443"; ma=2592000,h3-Q050=":443"; ma=2592000,h3-Q046=":443"; ma=2592000,h3-Q043=":443"; ma=2592000,quic=":443"; ma=2592000; v=“46,43”
Something else I noticed is Amazon Linux 2 requires a different command to enable EPEL. However, upon issuing the command to enable it, which is recommended by AWS, I encounter the following error:
sudo yum install http://dl.fedoraproject.org/pub/epel/epel-release-latest-7.noarch.rpm
Failed to set locale, defaulting to C
Loaded plugins: extras_suggestions, langpacks, priorities, update-motd
Cannot open: http://dl.fedoraproject.org/pub/epel/epel-release-latest-7.noarch.rpm. Skipping.
Error: Nothing to do
Researching more into this issue has revealed that the problem lies in the VPC of AWS and has probably nothing to do with Certbot.
