Issues with Registering
My domain is: thekings.staffs.sch.uk
I keep getting this error - Failed to register account with certificate authority, the request was abandoned , the request was canceled.
I have checked the server is unfiltered but need this working. We previously had this working due to an older server but upgraded this and it's having a hissy fit..
Kind Regards
Hi @BMorgan, and welcome to the LE community forum :slight_smile:
Please take the time to answer as many of the Help topic questions as possible:
Help us to help you!
Also, worth noting:
[multiple IPs]
Addresses: 165.160.15.20
           165.160.13.20
Which software are you using? (I'm assuming something on Windows from the screenshot?)
From that computer, can you get to https://acme-v02.api.letsencrypt.org/directory using a web browser (or from a command-line tool like curl or something like Invoke-RestMethod https://acme-v02.api.letsencrypt.org/directory in Powershell? How about other web sites, like Google or https://valid-isrgrootx1.letsencrypt.org/ ?
Following the redirect for the HTTP-01 Challenge (assuming that is the challenge you are using)
Look good but the redirect goes from thekings.staffs.sch.uk to thekingscofeacademy.org
$ curl -Ii http://thekings.staffs.sch.uk/.well-known/acme-challenge/sometestfile
Date: Fri, 31 Mar 2023 15:54:33 GMT
Content-Length: 0
$ curl -Ii https://thekingscofeacademy.org
HTTP/2 200
date: Fri, 31 Mar 2023 15:54:44 GMT
content-type: text/html; charset=utf-8
content-length: 82755
status: 200 OK
vary: Cookie
x-content-type-options: nosniff
strict-transport-security: max-age=31536000 ; includeSubDomains
accept-ranges: bytes
Edited
This:
doesn't redirect to this:
it redirects to this:
[which is a trainwreck for HTTP-01 ACME challenge requests]
But we still don't know if they are using HTTP-01 or DNS-01 authentication.
[so, let's not get too far ahead of ourselves]
This already crossed that line:
Managed to sort this out.
