Issues when using with nginx compiled from source
Hello,
sudo certbot --nginx
NGINX derivative
built by gcc 5.4.0 20160609 (Ubuntu 5.4.0-6ubuntu1~16.04.12)
built with OpenSSL 1.1.1g 21 Apr 2020
TLS SNI support enabled
configure arguments: --prefix= is not officially supported by certbot
An unexpected error occurred:
ValueError: invalid literal for int() with base 10: ‘’
nginx-1.16.1
Ubuntu 16.04
NA
Yes
N/A
certbot 0.31.0
More Details:
  1. Installed https://certbot.eff.org/ from instructions provided
  2. Compiled nginx from source
  3. Nginx is running fine and VHost is enabled and accessible
  4. But when ran certbot, giving above mentioned issue
Can you run sudo nginx -V and share the outputs?
I also used self-compiled Nginx and never had a issue.
nginx version:
configure arguments: --prefix=/usr/share/nginx --sbin-path=/usr/sbin/nginx --modules-path=/usr/lib/nginx/modules --conf-path=/etc/nginx/nginx.conf --error-log-path=/var/log/nginx/error.log --http-log-path=/var/log/nginx/access.log --pid-path=/run/nginx.pid --lock-path=/var/lock/nginx.lock --user=nginx --group=nginx --http-client-body-temp-path=/var/lib/nginx/body --http-fastcgi-temp-path=/var/lib/nginx/fastcgi --http-proxy-temp-path=/var/lib/nginx/proxy --http-scgi-temp-path=/var/lib/nginx/scgi --http-uwsgi-temp-path=/var/lib/nginx/uwsgi --with-openssl=…/openssl-1.1.1g --with-openssl-opt=enable-ec_nistp_64_gcc_128 --with-openssl-opt=no-nextprotoneg --with-openssl-opt=no-weak-ssl-ciphers --with-openssl-opt=no-ssl3 --with-pcre=…/pcre-8.44 --with-pcre-jit --with-zlib=…/zlib-1.2.11 --with-compat --with-file-aio --with-threads --with-http_addition_module --with-http_auth_request_module --with-http_dav_module --with-http_flv_module --with-http_gunzip_module --with-http_gzip_static_module --with-http_mp4_module --with-http_random_index_module --with-http_realip_module --with-http_secure_link_module --with-http_slice_module --with-http_ssl_module --with-http_stub_status_module --with-http_sub_module --with-http_v2_module --with-mail --with-mail_ssl_module --with-stream --with-stream_realip_module --with-stream_ssl_module --with-stream_ssl_preread_module --with-debug --add-module=…/headers-more-nginx-module-0.33
Double checking and it seems like there’s an known issue with certbot Nginx. How to change nginx config path
Pinging @schoen for any update.
You might want to open an issue with certbot team at https://github.com/certbot/certbot/issues
