Issues running certbot command
sudo certbot --nginx
jq: error (at :0): Cannot iterate over null (null)
Hosted through AWS
Ubuntu v16.04
Domain is currently hosted through Bluehost, but that will soon be moved to AWS.
Yes.
I am currently connecting to my site’s server using SSH.
Cannot run this command either.
I have tried removing and reinstalling Certbot using snap, but that did not fix the issue. I was able to get Certbot to run on another site without seeing this issue. I cannot figure out what the difference is.
Hi @gariepyt,
That’s an unfortunate issue which is my fault, but hopefully we will get it fixed soon. For now, try this:
sudo snap install core && sudo snap refresh core
That’s all you should need to do to fix it. Having an up-to-date snapd package from apt would also fix it for Ubuntu 16.04.
By the way, if anybody else runs into this in the next week or so, and you haven’t run the above command yet, it’d be great if you could also post what your OS is and the output of snap version.
To be clear, my current understanding is that while it may technically be true that the fact you see the exact error text
is partially az’s fault, this problem occurring if core/snapd wasn’t updated existed before az made any changes and their changes improved a number of other things in the Certbot snap.
Welcome to the Let’s Encrypt Community :slightly_smiling_face:
Backward day has officially been accomplished.
If only we just started with solutions then worked backwards to the greeting. Where’s the fun in that though? :thinking:
That did it. Thanks!!
Thanks, still work for me, my system is Ubuntu 18.04
