My domain is: reefmc.com
I ran this command: sudo snap install --classic certbot
error: cannot perform the following tasks:
- Run configure hook of "certbot" snap if present (run hook "configure": / has 'other' write 40777)
My web server is (include version): Apache/2.4.41 (Ubuntu)
The operating system my web server runs on is (include version): Ubuntu 20.04 LTS
My hosting provider, if applicable, is: n/a
The version of my client is (e.g. output of certbot --version or certbot-auto --version if you're using Certbot): not installed yet
I tried googling this error which brought me to a few threads, one from this site, that recommended checking the permissions of the /var folder, and after users changed them to 0755 they reported that it would work. The problem is, as far as I can tell, my /var folder is already 0755 and i've even tried doing sudo chmod 0755 /var to no avail. Still produced that error after running the chmod
Thanks for reading
