Issues renewing my certificate
Hi for some reason I am unable to renew my certbot certificate. I have not had any problems in the past and I am able to navigate to my web server using the domain name and have checked on noir to ensure that the ip is correct and it is. I should be able to accept inbound connections to this port because I have no problem connecting to my server from Safari or Firefox, unless I am missing something. Really at a loss here. Thank you for any and all help.
giuseppe-server.ddns.net
sudo certbot renew
sudo certbot renew
Processing /etc/letsencrypt/renewal/giuseppe-server.ddns.net.conf
Renewing an existing certificate for giuseppe-server.ddns.net
Domain: giuseppe-server.ddns.net
Type: connection
Detail: 104.169.167.177: Fetching http://giuseppe-server.ddns.net/.well-known/acme-challenge/{LONG_ALPHANUMERIC_STRING}: Timeout during connect (likely firewall problem)
Failed to renew certificate giuseppe-server.ddns.net with error: Some challenges have failed.
/etc/letsencrypt/live/giuseppe-server.ddns.net/fullchain.pem (failure)
nginx 1.22.1-9
PRETTY_NAME="Debian GNU/Linux 12 (bookworm)"
NAME="Debian GNU/Linux"
VERSION_ID="12"
VERSION="12 (bookworm)"
VERSION_CODENAME=bookworm
I can login to root shell on my machine (yes or no, or I don't know):
The version of my client is (e.g. output of certbot --version or certbot-auto --version if you're using Certbot): certbot 2.1.0
Yeah, I see HTTPS (port 443) connections working just fine too.
But, HTTP (port 80) are not reaching you with error from Let's Encrypt "Timeout during connect". The --standalone option requires exclusive use of port 80 so do you stop your nginx server before running certbot renew? Or, how do you handle port 80?
yes I have a script that turns it off renew and turns it back on overnight. When I did this yes I stopped nginx and ran certbot renew. What could cause port 80 to not be reachable? It is allowed through my firewall and also allowed on my routers. When I check open ports while nginx is running port 80 is in use but when I stop it nothing else is using port 80. I am really stumped...
Well, if nginx should "see" HTTP (port 80) requests right now then something is blocking port 80.
See, for example, this result: Let's Debug
Usually the reason is a firewall. Does your router have firewall settings?
Second most often reason is port forwarding, NAT, or other network routing at your end is faulty.
More rare ... could your ISP have started blocking port 80 inbound to you?
You should try an http request from outside your own network. Like a mobile phone with wifi disabled. Be sure to use http://(domain)
I am pretty sure you will get the same timeout problem as Let's Encrypt, Let's Debug, and tests from my own test server :slight_smile:
Ok so thank you for your help I was able to get it renewed. I checked my router and port 80 WAS set to forward that port as well as 443. For some reason it was not doing that, I had to remove it from the port forwarding list and re-add to the list, and then when I ran certbot renew it worked fine. Thank You!
