Issue with Lets Encrypt Issuance for Sub Domain
Error: Could not issue a Let's Encrypt SSL/TLS certificate for dev.manage.yumitos.com . Authorization for the domain failed.
Details
Invalid response from https://acme-v02.api.letsencrypt.org/acme/authz-v3/10627732458.
Details:
Type: urn:ietf:params:acme:error:connection
Status: 400
Detail: Fetching https://dev.manage.yumitos.com/.well-known/acme-challenge/NRggFkvxyWsp1ETKmIA1NL0luZ4l9Zp1_pH7fH1Azik: Connection reset by peer
Hi @shethchirag
please read your error message:
Checking http your server redirects to https. But your https configuration is buggy.
So you have two options:
  • Fix your https, so it works
  • Remove the redirect http -> https if the path starts with /.well-known/acme-challenge.
how can i remove? As it takes as default when i create certificate using Lets Encrypt in Plesk
