Hello,
I am facing an error after a while when I use the docker container in a Dockerfile.
Here is my docker file :
FROM certbot/certbot:latest
RUN pip install --upgrade pip
RUN pip install certbot-plugin-gandi
RUN pip install certbot-dns-infomaniak
RUN pip install certbot-dns-ovh
RUN pip install certbot-dns-cloudflare
The build works fine :
[+] Building 8.5s (10/10) FINISHED docker:default
=> [certbot internal] load build definition from Dockerfile 0.0s
=> => transferring dockerfile: 305B 0.0s
=> [certbot internal] load metadata for docker.io/certbot/certbot:latest 0.4s
=> [certbot internal] load .dockerignore 0.0s
=> => transferring context: 128B 0.0s
=> CACHED [certbot 1/6] FROM docker.io/certbot/certbot:latest@sha256:4d8875e85a2af373262914e15c0a149e1985c5bbd05ac433fe4763f465020fcf 0.0s
=> [certbot 2/6] RUN pip install --upgrade pip 0.6s
=> [certbot 3/6] RUN pip install certbot-plugin-gandi 3.1s
=> [certbot 4/6] RUN pip install certbot-dns-infomaniak 0.7s
=> [certbot 5/6] RUN pip install certbot-dns-ovh 2.0s
=> [certbot 6/6] RUN pip install certbot-dns-cloudflare 1.5s
=> [certbot] exporting to image 0.1s
=> => exporting layers 0.1s
=> => writing image sha256:d108ff26543a38b3d1248b6b020c5e578ef28a8bc1186b10e2e798690c250d7c 0.0s
=> => naming to docker.io/library/certbot-certbot 0.0s
But then, when I try to use it, I get the following error :
root @ master: /opt/docker/certbot 15 # docker compose -f $CERTBOT_HOME/docker-compose.yml run --rm certbot renew
File "/usr/local/lib/python3.12/importlib/metadata/__init__.py", line 397, in from_name
return next(cls.discover(name=name))
StopIteration
File "/usr/local/bin/certbot", line 33, in <module>
sys.exit(load_entry_point('certbot', 'console_scripts', 'certbot')())
File "/usr/local/bin/certbot", line 22, in importlib_load_entry_point
for entry_point in distribution(dist_name).entry_points
File "/usr/local/lib/python3.12/importlib/metadata/__init__.py", line 862, in distribution
return Distribution.from_name(distribution_name)
File "/usr/local/lib/python3.12/importlib/metadata/__init__.py", line 399, in from_name
raise PackageNotFoundError(name)
importlib.metadata.PackageNotFoundError: No package metadata was found for certbot
Usually when this happens I rebuild the image, and then re-run it.
But now I just can't get it to run
Thanks for your help !
