Issue with adding subdomain to existing config, nginx webroot method
My domain is: itsec.im
I ran this command: certbot certonly --webroot -w “/var/www/html” -d itsec.im -d www.itsec.im
It produced this output: - The following errors were reported by the server:
Domain: www.itsec.im
Detail: Invalid response from
http://www.itsec.im/.well-known/acme-challenge/SVUgJHLmngn15-cdvyZXEC4kuupFi8AQOX8GM9OBL68:
<html class="ie ie7 oldi" To fix these errors, please make sure that your domain name was entered correctly and the DNS A record(s) for that domain contain(s) the right IP address. My operating system is (include version): Debian 8 My web server is (include version): nginx 1.6.2 My hosting provider, if applicable, is: Digital Ocean I can login to a root shell on my machine (yes or no, or I don't know): yes I'm using a control panel to manage my site (no, or provide the name and version of the control panel): no Hi Guys Created the first cert fine for the non-www domain. Later realised I should have included www! My renew command works (which just renews the non-www). Nginx is set up to redirect http to https, excluding the lets-encrypt folder: server { listen 80; server_name itsec.im www.itsec.im; location /.well-known { alias /var/www/html/.well-known; } location / { return 301 https://itsec.im$request_uri; } } If I create a file inside /var/www/html/.well-known I can curl it from my other server using either www. or non-www. Not entirely sure what I'm missing here! Thanks
The DNS records for www.itsec.im point to a different IP:
➜  ~ dig itsec.im A
;; ANSWER SECTION:
itsec.im.		10800	IN	A	95.85.12.112
➜  ~ dig www.itsec.im A
;; ANSWER SECTION:
www.itsec.im.		10800	IN	CNAME	webredir.vip.gandi.net.
webredir.vip.gandi.net.	34134	IN	A	217.70.184.38
You’ll probably want to chang that to be point to the same IP (or CNAME to itsec.im), otherwise domain validation won’t work.
It’s an awful feeling when you realise you’re an idiot :sweat:
Thanks! I really should have spotted that.
EDIT: Confirmed working now. Thanks again. I feel a bit silly.
