My domain is: mrboogers.com
The operating system my web server runs on is (include version): Unraid 6.9.1
My hosting provider, if applicable, is: namecheap
The version of my client is (e.g. output of certbot --version or certbot-auto --version if you're using Certbot): certbot 1.18.0
Logs:
cronjob running on Mon Aug 23 02:08:01 ADT 2021
Running certbot renew
Processing /etc/letsencrypt/renewal/ombi.mrboogers.com.conf
Renewing an existing certificate for ombi.mrboogers.com and 3 more domains
Domain: homeassistant.mrboogers.com
Type: connection
Detail: Fetching http://homeassistant.mrboogers.com/.well-known/acme-challenge/En7Le0gVpGo1adIppFMWk_Dhbsby2q8bH0RFvFJILYk: Timeout during connect (likely firewall problem)
Failed to renew certificate ombi.mrboogers.com with error: Some challenges have failed.
/etc/letsencrypt/live/ombi.mrboogers.com/fullchain.pem (failure)
cronjob running on Tue Aug 24 02:08:00 ADT 2021
Type: connection
Detail: Fetching http://homeassistant.mrboogers.com/.well-known/acme-challenge/mEWooY7S_IL6tmrEX3WQiiOkZ6_qf0B_SbEGBp1X1Yc: Timeout during connect (likely firewall problem)
cronjob running on Wed Aug 25 02:08:00 ADT 2021
Type: connection
Detail: Fetching http://homeassistant.mrboogers.com/.well-known/acme-challenge/hw_8JiheyUdx0RwWR1OGE3Yh1QfBJiUPUI3vgDH_tvU: Timeout during connect (likely firewall problem)
cronjob running on Thu Aug 26 02:08:00 ADT 2021
Type: connection
Detail: Fetching http://homeassistant.mrboogers.com/.well-known/acme-challenge/5s0ecU2RoqBlUFMUXeNoMdOsmZAI5-oNwk1O7--7NK0: Timeout during connect (likely firewall problem)
cronjob running on Fri Aug 27 02:08:00 ADT 2021
Type: connection
Detail: Fetching http://homeassistant.mrboogers.com/.well-known/acme-challenge/bQ0L91w7rWEfOqXQw-LZeXtGXwvbq_UCzv95sPB9dRQ: Timeout during connect (likely firewall problem)
cronjob running on Sat Aug 28 02:08:00 ADT 2021
Type: connection
Detail: Fetching http://homeassistant.mrboogers.com/.well-known/acme-challenge/C_NeO4OL0M4Ox1CSl0dy8QRPZQT9cxrbIPjQIR3bSpg: Timeout during connect (likely firewall problem)
