Issue renewing and issuing some domains
Hello, I've been running into some issues when I run the certbot commands to renew and issue some certificates. The weird thing is that this just happens in some domains and not in others.
Server info
  • Debian 9
  • nginx 1.14.0
  • certbot 0.25.0
Domains that renew with any issue
  • margots.tech
  • margots.legal
Domain that is not renewing
  • margots.life
Domain I cannot issue a new certificate for
  • margots.biz
I'm running all the commands as root
  • Issue certificate: certbot --authenticator webroot --installer nginx
  • Renew certificate: certbot renew --dry-run
Issue certificate log
Failed authorization procedure. margots.biz (http-01): urn:ietf:params:acme:error:unauthorized :: The client lacks sufficient authorization :: Invalid response from http://margots.biz/.well-known/acme-challenge/INRvTgRg_OWpmJs89YcOs5oF-d5Bg8AIS5CGHl0VNpc: "<html>\r\n<head><title>404 Not Found</title></head>\r\n<body bgcolor=\"white\">\r\n<center><h1>404 Not Found</h1></center>\r\n<hr><center>", www.margots.biz (http-01): urn:ietf:params:acme:error:unauthorized :: The client lacks sufficient authorization :: Invalid response from http://www.margots.biz/.well-known/acme-challenge/a5GlZ_L3biFAL6WguhOempBDtJAQEJfSXjJcNvQh24I: "<html>\r\n<head><title>404 Not Found</title></head>\r\n<body bgcolor=\"white\">\r\n<center><h1>404 Not Found</h1></center>\r\n<hr><center>"
   Domain: margots.biz
   Type:   unauthorized
   Detail: Invalid response from
   Domain: www.margots.biz
   Type:   unauthorized
Renew certificate log
Processing /etc/letsencrypt/renewal/margots.tech.conf
Plugins selected: Authenticator webroot, Installer nginx
http-01 challenge for margots.tech
http-01 challenge for www.margots.tech
new certificate deployed with reload of nginx server; fullchain is
/etc/letsencrypt/live/margots.tech/fullchain.pem
Processing /etc/letsencrypt/renewal/margots.legal.conf
Running pre-hook command: nginx -s stop
http-01 challenge for margots.legal
http-01 challenge for www.margots.legal
new certificate deployed without reload, fullchain is
/etc/letsencrypt/live/margots.legal/fullchain.pem
Processing /etc/letsencrypt/renewal/margots.life.conf
http-01 challenge for margots.life
http-01 challenge for www.margots.life
Attempting to renew cert (margots.life) from /etc/letsencrypt/renewal/margots.life.conf produced an unexpected error: Failed authorization procedure. www.margots.life (http-01): urn:ietf:params:acme:error:connection :: The server could not connect to the client to verify the domain :: Fetching http://www.margots.life/.well-known/acme-challenge/_PYaKN9xClhdwaxplaeUY79CmqzZYX6poA8ARZsPOJQ: Connection refused, margots.life (http-01): urn:ietf:params:acme:error:connection :: The server could not connect to the client to verify the domain :: Fetching http://margots.life/.well-known/acme-challenge/B0grIz_PYRRns9JE9danHW8Nfs3OfH4inTYP179ULPQ: Connection refused. Skipping.
The following certs could not be renewed:
  /etc/letsencrypt/live/margots.life/fullchain.pem (failure)
**          (The test certificates below have not been saved.)
The following certs were successfully renewed:
  /etc/letsencrypt/live/margots.tech/fullchain.pem (success)
  /etc/letsencrypt/live/margots.legal/fullchain.pem (success)
**          (The test certificates above have not been saved.)
Running post-hook command: nginx
   Domain: www.margots.life
   Type:   connection
   Detail: Fetching
   Connection refused
   Domain: margots.life
   Type:   connection
   Detail: Fetching
   Connection refused
Configuration files
All the configuration files are the same, will show output of diff command
margots.life
6c6
<     server_name .margots.legal www.margots.legal;
>     server_name .margots.life www.margots.life;
17,18c17,18
<     set $domain margots.legal;
<     set $base /var/www/margots.legal;
>     set $domain margots.life;
>     set $base /var/www/margots.life;
23c23
29,31c29,31
<     ssl_certificate /etc/letsencrypt/live/margots.legal/fullchain.pem;
<     ssl_certificate_key /etc/letsencrypt/live/margots.legal/privkey.pem;
<     ssl_trusted_certificate /etc/letsencrypt/live/margots.legal/fullchain.pem;
>     ssl_certificate /etc/letsencrypt/live/margots.life/fullchain.pem;
>     ssl_certificate_key /etc/letsencrypt/live/margots.life/privkey.pem;
>     ssl_trusted_certificate /etc/letsencrypt/live/margots.life/fullchain.pem;
34,35c34,35
<     access_log /var/log/nginx/margots.legal.access.log;
<     error_log /var/log/nginx/margots.legal.error.log warn;
>     access_log /var/log/nginx/margots.life.access.log;
>     error_log /var/log/nginx/margots.life.error.log warn;
margots.biz
6c6
>     server_name margots.biz www.margots.biz;
7a8
>     # Include
17,18c18,19
>     set $domain margots.biz;
>     set $base /var/www/margots.biz;
23c24
29,31c30,32
>     #ssl_certificate /etc/letsencrypt/live/margots.biz/fullchain.pem;
>     #ssl_certificate_key /etc/letsencrypt/live/margots.biz/privkey.pem;
>     #ssl_trusted_certificate /etc/letsencrypt/live/margots.biz/fullchain.pem;
34,35c35,36
>     access_log /var/log/nginx/margots.biz.access.log;
>     error_log /var/log/nginx/margots.biz.error.log warn;
I've a location rule for the acme-challenge that's the following:
# ACME-challenge
location '/.well-known/acme-challenge' {
    default_type "text/plain";
    root /var/www/$domain/.well-known/acme-challenge;
All domains you mentioned above returns a Connection_Reset error when i visit in browser.
HTTP/1.1 302 Moved Temporarily
Server: nginx
Date: Mon, 08 Oct 2018 19:05:06 GMT
Content-Type: text/html
Content-Length: 154
curl: (35) OpenSSL SSL_connect: SSL_ERROR_SYSCALL in connection to www.margots.life:443
Why do you choose to use this type of root instead of defining the root at virtual host level? (It is working correctly though)
Can you please elaborate on why do you choose to use webroot authenticator instead of the Nginx one?
Thank you
I’m actually not sure what’s the solution in here…
Since this Nginx virtual host file differences dramatically from my version…
(Hope others could recogize this type of vhost…)
Thank you
Hi @marianord
there is an inconsistent configuration. margots.tech uses http-01 - validation:
But margots.legal uses a standalone
So first nginx -s stop
But then margots.life uses
There is no nginx restart, so
Connection refused.
So first cleanup your conf files in
and change them all to
Or possibly to
Authenticator nginx, Installer nginx
PS: A little bit more info:
Standalone starts an own webserver and needs port 80, so the running nginx is stopped.
But after that the nginx isn't restartet, so the following domain doesn't allow a connect.
So it's a problem of the order of your renews.
PS:
it's a diff result, not the original file.
Thanks, I went all the way to redo the nginx configuration and delete all the certificates. And they are now working.
Really thankful for everyone that helped :hugs:
