Issue installing on RHEL 7.7
Having exact same issue as described in : Unable to install in RHEL 7.7 on EC2
Rhel 7.7, Developers Subscription
Issues is that package Can be installed if using Amazon’s images, I believe because in there images they are implementing there local repos to be used, but if using on premise, Real deployment and using RH repo directly, it is impossible to deploy even with enabled epel repo,
Regards
The easy solution is to use acme.sh, uacme, or getssl instead of certbot.
:slight_smile: Guys
I’m reporting this to help devs fix the issue, which makes it out of RHEL
As a solution I’ll go to digicert wildcard and going to use there API :slight_smile:
Regards
Zaza
This is a packaging issue, not a certbot or letsencrypt issue. Before spending hundreds of dollars, try another client: https://letsencrypt.org/docs/client-options/
