Issue Certficate for Azure WAF
certbot certonly --webroot -w /var/www/mydomain/folder/Test2 -d www.mydomain.fr -d mydomain.fr -w /var/www/mydomain/folder/Test1/ -d mydomain.de -d www.mydomain.de
Apache on a CentOS but we have an Web Application Firewall
Azure
I can login to a root shell on my machine
No
there are any way to issue certificate and install after on Web Application Firewall? I need the pfx file.
Yes,
You can use this command to combine the cert file and key file.
openssl pkcs12 -export -inkey your_private_key.key -in result.pem -name my_name -out final_result.pfx
Okay, but for some reason my input command doesn’t work
What’s the output when you try to run that? “Doesn’t work” how?
