Is there a way to request a revoke of a cert?
If I lost my account key and the domain key, how can I revoke a cert ?
Thanks.
Hi @Neilpang,
You can follow the "Using a different authorized account" instructions from here: Revoking Certificates - Let's Encrypt
You will need to authorize the same domains as the certificate in question from a new account and then submit a revocation request for the original certificate.
Hope that helps,
Thank you. I will try soon.
