Is Let's Encrypt a 2048 bit encryption?
Hello, can someone please confirm is this Let’s Encrypt Service 2048 bit encryption?
Do you mean the private key that you use with the certificate ? that can be specified and could be 2048 or can be 4096 if you prefer.
Do you mean the cipher that you use ? This can again be specified in your webserver config.
