Is it possible to have certbot check https instead of http?
My domain is: crt.sh ID 12345434223
I ran this command: sudo certbot certonly --manual -d my.domain.com --dry-run
http-01 challenge for my.domain.com
NOTE: The IP of this machine will be publicly logged as having requested this
certificate. If you're running certbot in manual mode on a machine that is not
your server, please ensure you're okay with that.
Are you OK with your IP being logged?
(Y)es/(N)o: y
Create a file containing just this data:
8oBbsvmx4qhVIHdUCg-OLcyV_wrFa4TCBPdckI873Jg.mHUkueJuZCLXoeIboZRRwtEzPYfxXyii3Wml-LDIOzo
http://my.domain.com/.well-known/acme-challenge/8oBbsvmx4qhVIHdUCg-OLcyV_wrFa4TCBPdckI873Jg
Press Enter to Continue
Challenge failed for domain my.domain.com
   Domain: my.domain.com
   Type:   connection
   Detail: xxx.xxx.xxx.xxx: Fetching
   http://my.domain.com/.well-known/acme-challenge/8oBbsvmx4qhVIHdUCg-OLcyV_wrFa4TCBPdckI873Jg:
   Error getting validation data
My web server is (include version): nginx/1.18.0 (Ubuntu 20.04)
I can login to a root shell on my machine.
I'm NOT using a control panel to manage my site.
The version of my client is: certbot 0.40.0
Issue:
curl http://my.domain.com/.well-known/... yields (52) Empty reply from server
curl https://my.domain.com/.well-known/... yields 8oBbsvmx....Wml-LDIOzo
Hypothesis:
port 80 must be blocked above web server level, some time after creating the initial cert. I have no access to those settings.
Question:
Nginx Config:
  server_name     my.domain.com;
  location ^~ /.well-known/acme-challenge/ {
    alias /var/www/acme-challenge/;
    allow all;
    default_type "text/plain";
    # try_files $uri $uri/ @rewrites;
    proxy_pass              http://xxx.xxx.xxx.xxx; # Not localhost
    proxy_http_version      1.1;
    proxy_set_header        Upgrade $http_upgrade;
    proxy_set_header        Connection "Upgrade";
    # other settings
  ssl_certificate /etc/letsencrypt/live/my.domain.com/fullchain.pem; # managed by Certbot
  ssl_certificate_key /etc/letsencrypt/live/my.domain.com/privkey.pem; # managed by Certbot
  if ($host = my.domain.com) {
  } # managed by Certbot
  listen          80 proxy_protocol;
Only with an http redirect.
Check if you can use another challenge, either dns-01 or tls-alpn-01 (certbot doesn't support this last one, tho)
The nginx config redirects http to https (as managed by cerbot). Is this not enough?
I will check if my host has an API for dns-01 to work, since I also do not have zone editor access.
ALPN sounds complicated :sweat_smile:.
The HTTP->HTTPS redirect would be enough but requests to port 80 (HTTP) are being rejected by something.
You might try changing your
to just:
listen 80;
It doesn't look like you need proxy_protocol and maybe it is causing a problem.
We should really look at your entire nginx config. I would like to see if there is some other server block interfering (like one based on IP and not SNI).
Can you post the (long) output of this command. An upper case T is essential
sudo nginx -T
Thanks everyone.. after a lot of trial and error, I have found my problem..
I found an immortal nginx that was blocking certbot from authenticating. It is immortal because after stopping the service and killing the process, it would start itself back up again.
After finding the magic bullet pkill nginx, I managed to allow cerbot to 2: Spin up a temporary webserver (standalone) and renew the certificate successfully.
Now I just need to figure out what inside nginx would stop certbot from verifying the challenge (error 400)..
It probably never actually stopped when all other nginx processes were stopped.
Those types of processes are usually referred to as zombie processes - ones that no longer can be controlled and continue to operate until killed OR the system is rebooted.
Hi @elzix from the HTTP-01 challenge
"Our implementation of the HTTP-01 challenge follows redirects, up to 10 redirects deep. It only accepts redirects to “http:” or “https:”, and only to ports 80 or 443. It does not accept redirects to IP addresses. When redirected to an HTTPS URL, it does not validate certificates (since this challenge is intended to bootstrap valid certificates, it may encounter self-signed or expired certificates along the way).
The HTTP-01 challenge can only be done on port 80. Allowing clients to specify arbitrary ports would make the challenge less secure, and so it is not allowed by the ACME standard."
Edited: So the answer is NO for the HTTP-01 challenge, sorry. :frowning:
TLS-ALPN uses port 443 [which is commonly known as HTTPS].
So... technically, the answer is: YES, it can use HTTPS*.
[but not plane jane HTTPS]
Note: TLS-ALPN does use port 443 but it requires additional software and setup to complete the challenge.
You are correct, once again, @rg305! :slight_smile:
Thanks!
:beers:
Please see Certbot 2.10.0 Release and follow the instructions from https://certbot.eff.org/ to properly install.
A real *nix zombie process won't even get killed by kill -9 :confused: If a process has the "Z" status in (h)top, only a reboot gets rid of it unfortunately..
Yes, the part that I was trying to address mostly [which seems to have lost focus] was:
I doubt that it was ever stopped at all.
Thus, did NOT restart all by itself.
I will try this on Monday, thanks.
As a historical note, it used to be possible to do an equivalent challenge starting on port 443, but it was discovered that this caused problems for some shared hosting setups (allowing one customer to obtain certificates for another customer), so that functionality was intentionally disabled. (To be more precise, there were two different versions of simple port 443 challenges, both of which ultimately had some unduly high risks for shared hosting environments; one of them was removed before Let's Encrypt even launched, while the other one was removed in 2019. Details of both are in section 4.3 of the Let's Encrypt academic paper.)
As others have mentioned, you can do the TLS-ALPN challenge on port 443 now, but it's kind of complicated and most people currently wouldn't be able to use it unless their web servers directly provide support for it.
Nginx was running fine before the change. However, after the change a lot of other problems I had were fixed. Thanks.
