Invalid response acme challenge - same IP as subdomain
Hi there,
I have an issue creating my ssl certicate for my main domain. The A-Entry in my DNS settings lead to the same IP of both, subdomain and main one.
Now strangely I could create the certificate for the subdomain, but not for the main one. I get following error:
Detail: Invalid response from
http://glaubs.net/.well-known/acme-challenge/0xjQzCjpQg1WRlzhMM4ghucot1xnlg-CsMty_LkSCaQ:
“\r\n404 Not Found\r\n<body
bgcolor=“white”>\r\n
404 Not
Found
\r\n
I have no idea where the problem could be.
Thanks for your help!
My domain is: glaubs.net (subdomain: office.glaubs.net)
I ran this command: certbot
My web server is (include version): Apache/2.4.29 (Ubuntu)
My hosting provider, if applicable, is: netcup
I’m using a control panel to manage my site (no, or provide the name and version of the control panel): yes
They don’t have exactly the same IPs:
glaubs.net.         (insecure)  86400  A     185.162.248.168
glaubs.net.         (insecure)  86400  AAAA  2a03:4000:30:3633::11:3954
office.glaubs.net.  (insecure)  86400  A     185.162.248.168
Are you sure the IPv6 address is correct?
Edit:
The IPv6 address is running an Nginx web server, so it’s pointed to a different server, or set up differently.
https://letsdebug.net/glaubs.net/5972
Oh, I only checked the A record. Should I just delete the AAAA record or what would you recommend? To be honest I’m not sure if or how important it is to have the IPV6 IP as well.
It’s good to support IPv6, but the most important thing is for your DNS records to be correct.
Is that your IPv6 address?
It does have a valid certificate for https://glaubs.net/. It has a web page saying “Hier entsteht eine neue Webseite.”
Are you using both Apache and Nginx?
