I have WHM and cPanel installed on a VPS. WHM allowed me to install the plugin created by cPanel company to use LetsEncrypt. Now LetsEncrypt appears as the SSL provider. I read this Help page: https://letsencrypt.org/getting-started/
and I believe I have covered this step of making LetsEncrypt work inside the WHM using the plugin .
What are the next steps?
Do I have to ask my hosting provider: https://virmach.com
if LetsEncrypt is supported in the VPS server or the mere fact that I have succeeded in installing the LetsEncrypt plugin inside WHM means that LetsEncrypt is supported?
Could you please pass me a guide to start installing Certificates from inside WHM and getting the certificate from LetsEncrypt ?
Thanks
Hi @robertolito,
Did you then try to activate a certificate for your site in cPanel?
I am new activating Certificates. Can you give me a guide?
I believe it might be something like this:
https://www.inmotionhosting.com/support/website/cpanel/add-delete-autossl-cpanel
AutoSSL is designed to work on a non-interactive basis.
That is to say, you shouldn’t need to ask cPanel to issue a certificate, it will happen automatically if validation is possible. This usually happens within a few minutes.
It is possible to force it via the WHM interface, if you are the root admin.
Otherwise you’d need to contact the WHM admin/host and ask them to check the AutoSSL logs.
Thanks for the correction, @_az! You can see that I haven’t used cPanel myself.
@_az So, how do I tell AutoSSL to give a certificate to a certain domain ? Will it do it automatically without me requesting it? I don’t have to point at the domain somehow to indicate which domain I want the certificate on? By the way, I am the WHM admin/ host
It should do it automatically soon after the domain is added to cPanel. AutoSSL will run for all domains on the server that it can manage, no opt-in require (by default).
If it isn’t, then there’s probably something blocking the functionality (such as failing domain validation).
You can go to WHM -> Manage AutoSSL and check logs on a per-user basis, force runs for users etc: https://documentation.cpanel.net/display/68Docs/Manage+AutoSSL
Failing that, cPanel support should be able to help you with this.
Thank you. Will try that.
Go to WHM > Search for “SSL” > Select “Manage Service SSL Certificates” > Browse and select available certificate (or copy/paste) > Choose the services you prefer to install SSL on > Then, “Install”. This should do it. Let me know how it goes!
