Installing and configuring certbot on google compute engine
My domain is: magentamagazine.co.za
It produced this output: Domain: magentamagazine.co.za
Type: tls
Detail: remote error: tls: handshake failure
Domain: www.magentamagazine.co.za
Type: tls
My web server is (include version): Apache HTTP Server (2.4.10)
The operating system my web server runs on is (include version):Debian 8
My hosting provider, if applicable, is: Google Cloud Console
I’m using a control panel to manage my site (no, or provide the name and version of the control panel):no
This domain appears to use CloudFlare. When you use CloudFlare, they provide SSL for the connection between CloudFlare and your visitors, but you typically also need to secure the connection between CloudFlare and your origin server in Google Compute Engine.
Unfortunately, the default method certbot uses to verify your domain (tls-sni-01) will not work with CloudFlare intercepting your SSL, because it relies on being able to temporarily present a special certificate. Since your server is hidden behind CloudFlare, Let’s Encrypt will only ever see CloudFlare’s certificates and this does not work.
You can instead force certbot to use a different method of verification called http-01 or webroot authentication, which just places a special file in your web directory and typically works fine with CloudFlare. In order to use it, you will need to figure out the local directory on your domain that contains the files that are served to the Internet. In most distributions, this is located at /var/www/html.
In that configuration, you would invoke certbot like so:
sudo certbot run -a webroot -i apache -w /var/www/html -d magentamagazine.co.za -d www.magentamagazine.co.za
Thanks I will try it out.
this is technically not correct
You can use CloudFlare to proxy traffic in which case CloudFlare certificates will be used
However you can choose to pass traffic through by un-ticking the cloudflare icon.
This will mean that the traffic will be passed through to the origin server and the origin server will need to provide SSL.
I use cloudflare for most of my domains but don’t use their certificate and proxying services.
As you can see from the screenshot below 3 of my domains are pass through (grey icon) and one (www) is proxied by cloudFlare.
Andrei
