My domain is: edupro.academy and lms.edupro.academy
My web server is (include version): Apache 2.4
The operating system my web server runs on is (include version): Ubuntu 22.04
My hosting provider, if applicable, is: my server
I can login to a root shell on my machine (yes or no, or I don't know): yes - port 22,80,443 open
The version of my client is (e.g. output of certbot --version or certbot-auto --version if you're using Certbot): 1.21
I have made a successful installation for both VHosts, edupro.academy and lms.edupro.academy. Both can be accessed via http but not via https.
I have set my DNS records to : @ > server ip address and www > ip address and finally created a CNAME with lms pointing to edupro.academy
Yes, much looks good. First thing to check is your router NAT config for port 443. Your port 80 is working right so compare to that (except of course use port 443).
However when i run an ssl check at my domain name provider, i get :
443 port seems to be filtered, check your firewall/server configuration.
Hostname* edupro.academy
Port* 443
The thing is that i also have access via vpn to the server's local address 10.10.x.x in which case the https access should not be affected by the external firewall rules.
