Installation not working
My domain is: narutorp.fr
I ran this command: sudo certbot --nginx
No names were found in your configuration files. Please enter in your domain
name(s) (comma and/or space separated) (Enter 'c' to cancel): narutorp.fr
The operating system my web server runs on is (include version): Ubuntu 20.04
My hosting provider, if applicable, is: ouiheberg
yes, Azuriom
The version of my client is (e.g. output of certbot --version or certbot-auto --version if you're using Certbot): certbot 1.15.0
the installation works but I don't have any https on my website
It did? I'm surprised, as I'd think the certbot nginx plugin wouldn't be able to install the certificate if it couldn't find any hostname in your nginx configuration to begin with..
Please post the output of:
sudo nginx -T
And please post three backticks (```) above and below the contents if you paste it in a post here, so it gets formatted properly.
user                 www-data;
pid                  /run/nginx.pid;
worker_processes     auto;
worker_rlimit_nofile 65535;
events {
    multi_accept       on;
    worker_connections 65535;
http {
    charset              utf-8;
    sendfile             on;
    tcp_nopush           on;
    tcp_nodelay          on;
    server_tokens        off;
    log_not_found        off;
    types_hash_max_size  2048;
    client_max_body_size 16M;
    # MIME
    include              mime.types;
    default_type         application/octet-stream;
    # Logging
    access_log           /var/log/nginx/access.log;
    error_log            /var/log/nginx/error.log warn;
    # SSL
    ssl_session_timeout  1d;
    ssl_session_cache    shared:SSL:10m;
    ssl_session_tickets  off;
    # Diffie-Hellman parameter for DHE ciphersuites
    ssl_dhparam          /etc/nginx/dhparam.pem;
    # Mozilla Intermediate configuration
    ssl_protocols        TLSv1.2 TLSv1.3;
    ssl_ciphers          ECDHE-ECDSA-AES128-GCM-SHA256:ECDHE-RSA-AES128-GCM-SHA256:ECDHE-ECDSA-AES256-GCM-SHA384:ECDHE-RSA-AES256-GCM-SHA384:ECDHE-ECDSA-CHACHA20-POLY1305:ECDHE-RSA-CHACHA20-POLY1305:DHE-RSA-AES128-GCM-SHA256:DHE-RSA-AES256-GCM-SHA384;
    # OCSP Stapling
    ssl_stapling         on;
    ssl_stapling_verify  on;
    resolver             1.1.1.1 1.0.0.1 valid=60s;
    resolver_timeout     2s;
        # Cloudflare
        include '/etc/nginx/globals/cloudflare-ip-list.conf';
        real_ip_header CF-Connecting-IP;
    # Load configs
    include              /etc/nginx/conf.d/*.conf;
    include              /etc/nginx/sites-enabled/*;
types {
    text/html                                        html htm shtml;
    text/css                                         css;
    text/xml                                         xml;
    image/gif                                        gif;
    image/jpeg                                       jpeg jpg;
    application/javascript                           js;
    application/atom+xml                             atom;
    application/rss+xml                              rss;
    text/mathml                                      mml;
    text/plain                                       txt;
    text/vnd.sun.j2me.app-descriptor                 jad;
    text/vnd.wap.wml                                 wml;
    text/x-component                                 htc;
    image/png                                        png;
    image/svg+xml                                    svg svgz;
    image/tiff                                       tif tiff;
    image/vnd.wap.wbmp                               wbmp;
    image/webp                                       webp;
    image/x-icon                                     ico;
    image/x-jng                                      jng;
    image/x-ms-bmp                                   bmp;
    font/woff                                        woff;
    font/woff2                                       woff2;
    application/java-archive                         jar war ear;
    application/json                                 json;
    application/mac-binhex40                         hqx;
    application/msword                               doc;
    application/pdf                                  pdf;
    application/postscript                           ps eps ai;
    application/rtf                                  rtf;
    application/vnd.apple.mpegurl                    m3u8;
    application/vnd.google-earth.kml+xml             kml;
    application/vnd.google-earth.kmz                 kmz;
    application/vnd.ms-excel                         xls;
    application/vnd.ms-fontobject                    eot;
    application/vnd.ms-powerpoint                    ppt;
    application/vnd.oasis.opendocument.graphics      odg;
    application/vnd.oasis.opendocument.presentation  odp;
    application/vnd.oasis.opendocument.spreadsheet   ods;
    application/vnd.oasis.opendocument.text          odt;
    application/vnd.openxmlformats-officedocument.presentationml.presentation
                                                     pptx;
    application/vnd.openxmlformats-officedocument.spreadsheetml.sheet
                                                     xlsx;
    application/vnd.openxmlformats-officedocument.wordprocessingml.document
                                                     docx;
    application/vnd.wap.wmlc                         wmlc;
    application/x-7z-compressed                      7z;
    application/x-cocoa                              cco;
    application/x-java-archive-diff                  jardiff;
    application/x-java-jnlp-file                     jnlp;
    application/x-makeself                           run;
    application/x-perl                               pl pm;
    application/x-pilot                              prc pdb;
    application/x-rar-compressed                     rar;
    application/x-redhat-package-manager             rpm;
    application/x-sea                                sea;
    application/x-shockwave-flash                    swf;
    application/x-stuffit                            sit;
    application/x-tcl                                tcl tk;
    application/x-x509-ca-cert                       der pem crt;
    application/x-xpinstall                          xpi;
    application/xhtml+xml                            xhtml;
    application/xspf+xml                             xspf;
    application/zip                                  zip;
    application/octet-stream                         bin exe dll;
    application/octet-stream                         deb;
    application/octet-stream                         dmg;
    application/octet-stream                         iso img;
    application/octet-stream                         msi msp msm;
    audio/midi                                       mid midi kar;
    audio/mpeg                                       mp3;
    audio/ogg                                        ogg;
    audio/x-m4a                                      m4a;
    audio/x-realaudio                                ra;
    video/3gpp                                       3gpp 3gp;
    video/mp2t                                       ts;
    video/mp4                                        mp4;
    video/mpeg                                       mpeg mpg;
    video/quicktime                                  mov;
    video/webm                                       webm;
    video/x-flv                                      flv;
    video/x-m4v                                      m4v;
    video/x-mng                                      mng;
    video/x-ms-asf                                   asx asf;
    video/x-ms-wmv                                   wmv;
    video/x-msvideo                                  avi;
# configuration file /etc/nginx/globals/cloudflare-ip-list.conf:
set_real_ip_from 173.245.48.0/20;
set_real_ip_from 103.21.244.0/22;
set_real_ip_from 103.22.200.0/22;
set_real_ip_from 103.31.4.0/22;
set_real_ip_from 141.101.64.0/18;
set_real_ip_from 108.162.192.0/18;
set_real_ip_from 190.93.240.0/20;
set_real_ip_from 188.114.96.0/20;
set_real_ip_from 197.234.240.0/22;
set_real_ip_from 198.41.128.0/17;
set_real_ip_from 162.158.0.0/15;
set_real_ip_from 172.64.0.0/13;
set_real_ip_from 131.0.72.0/22;
set_real_ip_from 104.16.0.0/13;
set_real_ip_from 104.24.0.0/14;
set_real_ip_from 2400:cb00::/32;
set_real_ip_from 2606:4700::/32;
set_real_ip_from 2803:f800::/32;
set_real_ip_from 2405:b500::/32;
set_real_ip_from 2405:8100::/32;
set_real_ip_from 2a06:98c0::/29;
set_real_ip_from 2c0f:f248::/32;
# configuration file /etc/nginx/sites-enabled/azuriom.conf:
        listen 80;
        server_name _;
        set $base /var/www/html;
        root $base/public;
        # logging
        access_log /var/log/nginx/azuriom.access.log;
        error_log /var/log/nginx/azuriom.error.log warn;
        # security
        include globals/security.conf;
        # general
        include globals/general.conf;
        # index.php
        index index.php;
        # index.php fallback
                try_files $uri $uri/ /index.php?$query_string;
        # handle .php
    location ~ \.php$ {
        fastcgi_pass unix:/var/run/php/php8.0-fpm.sock;
        include globals/php_fastcgi.conf;
        location /phpmyadmin {
           root /usr/share/;
           index index.php index.html index.htm;
           location ~ ^/phpmyadmin/(.+\.php)$ {
                   try_files $uri =404;
                   root /usr/share/;
                   fastcgi_pass unix:/run/php/php7.4-fpm.sock;
                   fastcgi_index index.php;
                   fastcgi_param SCRIPT_FILENAME $document_root$fastcgi_script_name;
                   include /etc/nginx/fastcgi_params;
           location ~* ^/phpmyadmin/(.+\.(jpg|jpeg|gif|css|png|js|ico|html|xml|txt))$ {
                   root /usr/share/;
# configuration file /etc/nginx/globals/security.conf:
# security headers
add_header X-Frame-Options           "SAMEORIGIN" always;
add_header X-XSS-Protection          "1; mode=block" always;
add_header X-Content-Type-Options    "nosniff" always;
add_header Referrer-Policy           "no-referrer-when-downgrade" always;
add_header Content-Security-Policy   "default-src 'self' http: https: data: blob: 'unsafe-inline'" always;
add_header Strict-Transport-Security "max-age=31536000; includeSubDomains" always;
# . files
location ~ /\.(?!well-known) {
    deny all;
# configuration file /etc/nginx/globals/general.conf:
# favicon.ico
location = /favicon.ico {
    log_not_found off;
    access_log    off;
# robots.txt
location = /robots.txt {
    log_not_found off;
    access_log    off;
# assets, media
location ~* \.(?:css(\.map)?|js(\.map)?|jpe?g|png|gif|ico|cur|heic|webp|tiff?|mp3|m4a|aac|ogg|midi?|wav|mp4|mov|webm|mpe?g|avi|ogv|flv|wmv)$ {
    expires    30d;
    access_log off;
# svg, fonts
location ~* \.(?:svgz?|ttf|ttc|otf|eot|woff2?)$ {
    add_header Access-Control-Allow-Origin "*";
    expires    30d;
    access_log off;
# gzip
gzip            on;
gzip_vary       on;
gzip_proxied    any;
gzip_comp_level 6;
gzip_types      text/plain text/css text/xml application/json application/javascript application/rss+xml application/atom+xml image/svg+xml;
# configuration file /etc/nginx/globals/php_fastcgi.conf:
# 404
try_files                     $fastcgi_script_name =404;
# default fastcgi_params
include                       fastcgi_params;
# fastcgi settings
fastcgi_buffers               8 16k;
fastcgi_buffer_size           32k;
# fastcgi params
fastcgi_param DOCUMENT_ROOT   $realpath_root;
fastcgi_param SCRIPT_FILENAME $realpath_root$fastcgi_script_name;
fastcgi_param PHP_ADMIN_VALUE "open_basedir=$base/:/usr/lib/php/:/tmp/";
# configuration file /etc/nginx/fastcgi_params:
fastcgi_param  QUERY_STRING       $query_string;
fastcgi_param  REQUEST_METHOD     $request_method;
fastcgi_param  CONTENT_TYPE       $content_type;
fastcgi_param  CONTENT_LENGTH     $content_length;
fastcgi_param  SCRIPT_NAME        $fastcgi_script_name;
fastcgi_param  REQUEST_URI        $request_uri;
fastcgi_param  DOCUMENT_URI       $document_uri;
fastcgi_param  DOCUMENT_ROOT      $document_root;
fastcgi_param  SERVER_PROTOCOL    $server_protocol;
fastcgi_param  REQUEST_SCHEME     $scheme;
fastcgi_param  HTTPS              $https if_not_empty;
fastcgi_param  GATEWAY_INTERFACE  CGI/1.1;
fastcgi_param  SERVER_SOFTWARE    nginx/$nginx_version;
fastcgi_param  REMOTE_ADDR        $remote_addr;
fastcgi_param  REMOTE_PORT        $remote_port;
fastcgi_param  SERVER_ADDR        $server_addr;
fastcgi_param  SERVER_PORT        $server_port;
fastcgi_param  SERVER_NAME        $server_name;
# PHP only, required if PHP was built with --enable-force-cgi-redirect
fastcgi_param  REDIRECT_STATUS    200;```
As you can see from the contents of /etc/nginx/sites-enabled/azuriom.conf there is NO reference to the Let's Encrypt certificate issued by certbot anywhere. So my doubt about certbot being able to install the certificate was correct: it isn't installed at all. Probably due to the fact you've got an underscore (_) as server_name set.
While that's a valid nginx configuration (as a catch all), if you only have a single site active on your server (narutorp.fr), it's probably better to change _ to narutorp.fr and run sudo certbot --nginx again and try to *install the certificate again. Please only try to re-install the certificate and not re-issue a new cert, as that's not necessary.
thanks a lot, that's working now!!
