Installation help
eclipse.bluemix.net
sudo /usr/local/bin/certbot-auto --apache
Installation was successful, but I saw this message:
Current timestamp 1576258596.37 does not correspond to newest reverter checkpoint; your clock probably jumped. Time travelling to 1576269725.62
Apache/2.4.7 (Ubuntu)
Ubuntu 14.04.2 LTS (GNU/Linux 3.13.0-51-generic x86_64)
no
certbot 1.0.0
The installation was successful except that I saw a message about current timestamp not correspond to newest reverter checkpoint. Not sure if that was a problem. However, I’m still not able to connect to: https://eclipse.bluemix.net
Not sure about the time-traveling (maybe try using NTP).
But with respect to https://eclipse.bluemix.net/
What does this show:
sudo /usr/local/bin/certbot-auto certificates
Found the following certs:
Certificate Name: eclipse.bluemix.net
Domains: eclipse.bluemix.net
Expiry Date: 2020-03-12 15:37:03+00:00 (VALID: 89 days)
Certificate Path: /etc/letsencrypt/live/eclipse.bluemix.net/fullchain.pem
Private Key Path: /etc/letsencrypt/live/eclipse.bluemix.net/privkey.pem
This is good :slight_smile:
apachectl -S
VirtualHost configuration:
*:443 eclipse.bluemix.net (/etc/apache2/sites-enabled/000-default-le-ssl.conf:2)
*:80 eclpkgs.dal.bluemix.net (/etc/apache2/sites-enabled/000-default.conf:1)
ServerRoot: “/etc/apache2”
Main DocumentRoot: “/var/www”
Main ErrorLog: “/var/log/apache2/error.log”
Mutex default: dir="/var/lock/apache2" mechanism=fcntl
PidFile: “/var/run/apache2/apache2.pid”
Define: DUMP_VHOSTS
Define: DUMP_RUN_CFG
User: name=“www-data” id=33
Group: name=“www-data” id=33
Interesting to see that port 80 is using the private hostname and port 443 is using the public hostname.
Will it help if I request another SSL certificate using the private domain name?
I'm not sure if you have anything available from internal (like timestamp issue), but your port 443 is not responding to any packet, and portqry showed that it's been filtered.
Can you try to confirm your firewall settings (or port forwarding if you are using residential/ business internet)?
If your server is not allowing external packets... There's no difference between public or private domain name. Also, if your domain is not "publicly registered" (tld in the public suffix list), you can't get a certificate with Let's Encrypt.
Thanks
