Inconsistent SSL Issue
My domain is: mbaglue.com
I ran this command: certbot certificates
 Found the following certs:
  Certificate Name: mbaglue.com
    Domains: mbaglue.com www.mbaglue.com
    Expiry Date: 2021-06-25 02:59:14+00:00 (VALID: 60 days)
    Certificate Path: /etc/letsencrypt/live/mbaglue.com/fullchain.pem
    Private Key Path: /etc/letsencrypt/live/mbaglue.com/privkey.pem
The operating system my web server runs on is (include version): Ubuntu 20.04
My hosting provider, if applicable, is: Digital Ocean
Certbot 0.40.0
Issue:
If you visit my site via Chrome or a few browser, on certain visits it shows that the certificate is invalid. This is further reconfirmed through third party sites like digicert.com/help.
However, if I run certbot certificates on my server, it says that my cert is not up for renewal. It seems like there are two certificates and the browser picks up one of these at a time. How do I sort this?
The browser will use the certificate presented by the webserver, which is the expired certificate.
The fact certbot shows a valid certificate does not always mean this is also used by the webserver. It depends on how you installed the certificate in the first place (which "installer" plugin was used, if any, or how the certificate was installed in the webserver if not done by an "installer" plugin and/or the use of a --deploy-hook to reload the webserver, if necessary) what needs to be done.
To the best of my memory, I didn't use any installer plugin.
What's the best way for me to locate the expired certificate on the server and delete it?
If you manually installed the certificate into your webserver, it depends on how you did that. Did you link directly to the files in the /etc/letsencrypt/live/ directory in your configuration file? If so, it would be enough to just reload your webserver so it picks up the current and valid one. If not, then it depends on how you did link to the certificate in your configuration file.
That's not the correct method of fixing this issue. Deleting the expired certificate would mean your webservers configuration becomes invalid.
