Improving my website for Lets Encrypt problems
NB: This is an update for the previous request under:
xorex.rocks
Virtualmin:Server Configuration:SSL Certificate:Let’s Encrypt:Request certificate for: Domain names listed here:
xorex.rocks
www.xorex.rocks
mail.xorex.rocks
ftp.xorex.rocks
Requesting a certificate for xorex.rocks, www.xorex.rocks, mail.xorex.rocks, ftp.xorex.rocks from Let's Encrypt ..
.. request failed : Web-based validation failed : Failed to request certificate :
  • File "/usr/share/webmin/webmin/acme_tiny.py", line 198, in *
  • main(sys.argv[1:])*
  • File "/usr/share/webmin/webmin/acme_tiny.py", line 194, in main*
  • signed_crt = get_crt(args.account_key, args.csr, args.acme_dir, log=LOGGER, CA=args.ca, disable_check=args.disable_check, directory_url=args.directory_url, contact=args.contact)*
  • File "/usr/share/webmin/webmin/acme_tiny.py", line 143, in get_crt*
  • raise ValueError("Wrote file to {0}, but couldn't download {1}: {2}".format(wellknown_path, wellknown_url, e))*
    ValueError: Wrote file to /home/xorex/public_html/.well-known/acme-challenge/jPro4J4ZCszZdqIdM9yN-PtXmICfY_1NJiAju06I1wU, but couldn't download http://ftp.xorex.rocks/.well-known/acme-challenge/jPro4J4ZCszZdqIdM9yN-PtXmICfY_1NJiAju06I1wU: Error:
    Url: http://ftp.xorex.rocks/.well-known/acme-challenge/jPro4J4ZCszZdqIdM9yN-PtXmICfY_1NJiAju06I1wU
    Data: None
    Response Code: 404
    Response:
    404 Not Found
    Not Found
    The requested URL was not found on this server.
, DNS-based validation failed : Failed to request certificate :
usage: acme_tiny.py [-h] --account-key ACCOUNT_KEY --csr CSR --acme-dir
  •                ACME_DIR [--quiet] [--disable-check]*
  •                [--directory-url DIRECTORY_URL] [--ca CA]*
  •                [--contact [CONTACT [CONTACT ...]]]*
acme_tiny.py: error: argument --acme-dir is required
Apache version 2.4.38 (apache2)
Debian Linux 10
OVH
Yes
Yes. Webmin version 1.942 Virtualmin version 6.09
No. Automated Virtualmin process
My site is currently working but “check-your-website.server-daten.de” tells me there are still more faults to conquer. Some of the issues are not clear to me and I wondered if there is a help guide for the site or a key that explains each error? For example, why does https://my IP address give a privacy error? The reverse dns is correctly set and I have never (to my knowledge) added and IP address to a certificate request. Is something else causing this?
So, Lets Encrypt is generating a certificate for the base domain and the “mail.” and “www.” Subdomains. However, as soon as I try to generate a certificate with one of the other subdomains (m., ftp. Webmail., admin., etc) if gives me an error. Normal http calls to the domain are being redirected to https successfully and the certificate is recognised through the redirection but a direct call on e.g., https://admin.xorex.rocks does not redirect (correct) but tells me ‘This Connection Is Not Private’, presumably because admin.xorex.rocks is not covered by the domain certificate.
All the subdomains are set up as A records not CNAME records which I understand is better and should not interfere with the Lets Encrypt process but can anyone confirm this please?
I also run a nameserver ns1.xorex.rocks on the server. For this subdomain I am able to generate a certificate for more of the subdomains. This far it covers
ns1.xorex.rocks
www.ns1.xorex.rocks
mail.ns1.xorex.rocks
m.ns1.xorex.rocks
ftp.ns1.xorex.rocks
However it will not accept “admin.” or “webmail.”
Why do the two servers react differently? How do I get them both to openly accept certification of the subdomains?
Hi @GeoffatMM
that's outside of this forum. Compare your result with other results and fix your errors.
That's a configuration problem of your VirtualMin. May be you don't have a working vHost configuration.
That's completely unrelevant.
??? Not really.
I cannot compare with others if I do not understand what I am comparing. Hence my request for a link to some form of guide for the check-your-website output. I can see what the letters refer to on the home page but there is no explanation of the colour coding etc. I am triying hard to sort this myself but it is not easy when the information is cryptic and there is not an explanation for it.
I have now got this running with the ftp. and m. domains. webmail. is on a redirection to Usermin and admin. to Webmin so LetsEncrypt cannot access the .well-known path as a consequence. However these now have the certificate copied to them so work fine.
However, xerxes.xorex.rocks which is configured identically to ftp. and m. will not work. On its own it correctly redirects to the https site for xorex.rocks and it can display the index file I have placed in the .well-known file when the path is added to the http request. Trying https to access it fails as there is no certificate. There is a redirection that excludes the .well-known path and http://xerxes.xorex.rocks/.well-known/acme-challenge/n_s-D6y57da7RCT00eqBxcGKcZXTa_pQz73wRIzhYZE opens the dummy acme-challenge folder and the file that I have inserted (feel free to check for yourselves).
So if everything is working correctly for this subdomain, why am I getting this error:
main(sys.argv[1:])
ValueError: Wrote file to /home/xorex/public_html/.well-known/acme-challenge/n_s-D6y57da7RCT00eqBxcGKcZXTa_pQz73wRIzhYZE, but couldn't download http://xerxes.xorex.rocks/.well-known/acme-challenge/n_s-D6y57da7RCT00eqBxcGKcZXTa_pQz73wRIzhYZE: Error:
Url: http://xerxes.xorex.rocks/.well-known/acme-challenge/n_s-D6y57da7RCT00eqBxcGKcZXTa_pQz73wRIzhYZE
Data: None
Response Code: 404
Response:
404 Not Found
Not Found
