Impossible to renew certificate via Virtualmin module, help please
Hello,
I’m french, so sorry for my poor english.
I have a big problem as I can’t renew my certificate for my domains.
The LE module should request a new certificate after 2 months, but it always fails.
Before, I could do it manually but now it’s not working anymore and I don’t know what to do.
Could you please help me with this problem ?
My domain is: hexa-gone.com
Requesting a certificate for hexa-gone.com, www.hexa-gone.com from Let’s Encrypt …
… request failed : Web-based validation failed : Failed to request certificate :
Parsing account key…
Parsing CSR…
Registering account…
Already registered!
Verifying hexa-gone.com
Wrote file to /home/hexa/www/.well-known/acme-challenge/dJSuupA-uO3bP9b-uMsYfw0e04Iw4tHs_ov24Up6Zxg, but couldn’t download http://hexa-gone.com/.well-known/acme-challenge/dJSuupA-uO3bP9b-uMsYfw0e04Iw4tHs_ov24Up6Zxg
** File “/usr/share/webmin/webmin/acme_tiny.py”, line 235, in **
** main(sys.argv[1:])**
** File “/usr/share/webmin/webmin/acme_tiny.py”, line 231, in main**
** signed_crt = get_crt(args.account_key, args.csr, args.acme_dir, args.dns_hook, args.cleanup_hook, log=LOGGER, CA=args.ca)**
** File “/usr/share/webmin/webmin/acme_tiny.py”, line 184, in get_crt**
** domain, challenge_status))**
ValueError: hexa-gone.com challenge did not pass: {u’status’: u’invalid’, u’validationRecord’: [{u’addressesResolved’: [u’87.98.156.47’, u’2001:41d0:c:f12::1’], u’url’: u’https://hexa-gone.com/.well-known/acme-challenge/dJSuupA-uO3bP9b-uMsYfw0e04Iw4tHs_ov24Up6Zxg’, u’hostname’: u’hexa-gone.com’, u’addressesTried’: [], u’addressUsed’: u’87.98.156.47’, u’port’: u’443’}, {u’addressesResolved’: [u’87.98.156.47’, u’2001:41d0:c:f12::1’], u’url’: u’http://hexa-gone.com/.well-known/acme-challenge/dJSuupA-uO3bP9b-uMsYfw0e04Iw4tHs_ov24Up6Zxg’, u’hostname’: u’hexa-gone.com’, u’addressesTried’: [], u’addressUsed’: u’2001:41d0:c:f12::1’, u’port’: u’80’}], u’keyAuthorization’: u’dJSuupA-uO3bP9b-uMsYfw0e04Iw4tHs_ov24Up6Zxg.wkeT0q-2nfnGV9BE9OYBzl8qA9tFe3W_lCv0KfPkhtM’, u’uri’: u’https://acme-v01.api.letsencrypt.org/acme/challenge/YERmZFfEAPJw7HcrMgLroWad81iyYc0fRBWIIE8Sgh0/2338938780’, u’token’: u’dJSuupA-uO3bP9b-uMsYfw0e04Iw4tHs_ov24Up6Zxg’, u’error’: {u’status’: 400, u’type’: u’urn:acme:error:connection’, u’detail’: u’Fetching https://hexa-gone.com/.well-known/acme-challenge/dJSuupA-uO3bP9b-uMsYfw0e04Iw4tHs_ov24Up6Zxg: Error getting validation data’}, u’type’: u’http-01’}
DNS-based validation failed : Failed to request certificate :
Parsing CSR…
Already registered!
Undefined subroutine &main::get_bind_zone_for_domain called at /usr/share/webmin/webmin/letsencrypt-dns.pl line 21.
ValueError: hexa-gone.com challenge did not pass: {u’status’: u’invalid’, u’keyAuthorization’: u’bl8vW_eTwGnsmQLRPeDvMOhDtuEvz0GUt-XeETx8ZJ8.wkeT0q-2nfnGV9BE9OYBzl8qA9tFe3W_lCv0KfPkhtM’, u’uri’: u’https://acme-v01.api.letsencrypt.org/acme/challenge/UfocqbwRm2Ub5oEp4KeJeSUTgWbkZNNTk-UAWWUZ0UE/2338939091’, u’token’: u’bl8vW_eTwGnsmQLRPeDvMOhDtuEvz0GUt-XeETx8ZJ8’, u’error’: {u’status’: 400, u’type’: u’urn:acme:error:connection’, u’detail’: u’DNS problem: NXDOMAIN looking up TXT for _acme-challenge.hexa-gone.com’}, u’type’: u’dns-01’}
My web server is : Apache 2.4.10
The operating system my web server runs on is (include version): Debian 8.9
My hosting provider, if applicable, is: OVH
I’m using a control panel to manage my site (no, or provide the name and version of the control panel): Virtualmin / Webmin 6.01.gpl-3
It probably has something to do with the different set up between IPv4 and IPv6.
With openssl, I can connect without a problem to hexa-gone.com. But openssls s_client connects to the IPv4 address..
When I try hexa-gone.com in Chromium, it connects to the IPv6 address with as a result:
This site can’t provide a secure connection
hexa-gone.com sent an invalid response.
ERR_SSL_PROTOCOL_ERROR
When I telnet to the IPv6 address behind hexa-gone.com, I get this (notice the port 443, i.e., HTTPS port):
osiris@desktop ~ $ telnet 2001:41d0:c:f12::1 443
Trying 2001:41d0:c:f12::1...
Connected to 2001:41d0:c:f12::1.
Escape character is '^]'.
GET / HTTP/1.1
Host: hexa-gone.com
HTTP/1.1 200 OK
Date: Sun, 29 Oct 2017 18:33:52 GMT
Server: Apache/2.4.10
Last-Modified: Thu, 09 Feb 2017 08:54:36 GMT
ETag: "0-54815216f8716"
Accept-Ranges: bytes
Content-Length: 0
Content-Type: text/html
Connection closed by foreign host.
osiris@desktop ~ $
So it looks like your IPv6 host isn't configured for HTTPS properly on port 443, while it should.
Why does this matter?
Because Let's Encrypt prefers IPv6 above IPv4 and does follow redirects. And you're redirecting HTTP to HTTPS, which results in the error above.
