Implementing custom captive portal with Google authentication on Mikrotik and SSL certificates
Continuing the discussion from Implementing custom captive portal with Google authentication on Mikrotik and SSL certificates:
clear
413 / 5,000
Resultados de traducción
Traducción
Hi, I have a confusion. I am implementing a custom captive portal on a hotspot system on mikrotik with google validation. Do I require an SSL certificate for it? I guess, because I have to deal with Google and they use HTTPS and the mikrotik only acts with HTTP so that SSL is enabled on it. implementing custom captive portal with Google authentication on Mikrotik and SSL certificates
2 posts were merged into an existing topic: Implementing custom captive portal with Google authentication on Mikrotik and SSL certificates
