I have to add :8443 to the end to reach it.
I would like for there to be a way to avoid that.
But I'm certainly able to reach the page by adding the port.
This issued certificate crt.sh | 8236700241, I believe is a match to below
$ openssl s_client -showcerts -servername bitwarden.glenspcservice.com bitwarden.glenspcservice.com:8443 < /dev/null
CONNECTED(00000003)
depth=0 CN = bitwarden.glenspcservice.com
verify error:num=20:unable to get local issuer certificate
verify return:1
verify error:num=21:unable to verify the first certificate
verify return:1
verify return:1
Certificate chain
0 s:CN = bitwarden.glenspcservice.com
a:PKEY: rsaEncryption, 2048 (bit); sigalg: RSA-SHA256
v:NotBefore: Dec 18 14:44:58 2022 GMT; NotAfter: Mar 18 14:44:57 2023 GMT
-----BEGIN CERTIFICATE-----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-----END CERTIFICATE-----
Server certificate
subject=CN = bitwarden.glenspcservice.com
issuer=C = US, O = Let's Encrypt, CN = R3
Peer signing digest: SHA256
Peer signature type: RSA-PSS
Server Temp Key: X25519, 253 bits
SSL handshake has read 1829 bytes and written 423 bytes
Verification error: unable to verify the first certificate
New, TLSv1.2, Cipher is ECDHE-RSA-AES256-GCM-SHA384
Server public key is 2048 bit
Secure Renegotiation IS supported
Compression: NONE
Expansion: NONE
No ALPN negotiated
SSL-Session:
Protocol : TLSv1.2
Cipher : ECDHE-RSA-AES256-GCM-SHA384
Session-ID: 6D65CB734996A302CDF6DB03240850ABF53257B8EBC61D98255C80E2CB7665A5
Session-ID-ctx:
Master-Key: 92284E438D64A40937F5A37A7C4B134EB12F32115FB72737492ADEFA14F067172AA00F23F96F83041ECD92B1A8FA58F2
PSK identity: None
PSK identity hint: None
SRP username: None
Start Time: 1671923205
Timeout : 7200 (sec)
Verify return code: 21 (unable to verify the first certificate)
Extended master secret: yes
DONE
I was pretty certain the previous sites I had configured had certificates that didn't match.
At any rate everything is working.
And I'm very happy I learned new things in the process.
