Icewarp renew problem
I have a mail server with Icewarp . I have a problem while using let's encrypt certificate . I was able to create/renew certificate . since 2 days , I couldn't renew the expired certificate .
I've checked the firewall logs and didn't find anything wrong.
the mailserver IP is 85.112.85.67
I've moved your thread to the #help section as I think that's a better fit for your thread and it will probably get more attention there. Also, in the #help section you would have been greeted with the following questionnaire. Please answer all the questions to the best of your knowledge:
