Is standard UTC time so Apr5 at 20:05:55
The whole appeal of YYYY-MM-DD is that no one uses YYYY-DD-MM, making it the only unambiguous date format.
The only idiotic date format known to mankind is the mm-dd-yyyy notation (mostly) used by the US.
All other formats use a variant of the correct order (small to big, big to small) instead of the weird mixed up format.
Small to big sorts incorrectly and is just as bad a format as the one that most in the US prefer.
ISO 8601 or nothing at all.
I made update certbot --apache and get this error
[root@ligalc ~]# certbot --apache
We recommend selecting either all domains, or all domains in a VirtualHost/server block.
1: ligalc.ru
2: www.ligalc.ru
Requesting a certificate for ligalc.ru
Certificate is saved at: /etc/letsencrypt/live/ligalc.ru/fullchain.pem
Key is saved at: /etc/letsencrypt/live/ligalc.ru/privkey.pem
This certificate expires on 2024-07-04.
Certbot has set up a scheduled task to automatically renew this certificate in the background.
Deploying certificate
Successfully deployed certificate for ligalc.ru to /etc/httpd/conf.d/vhosts-le-ssl.conf
Job for httpd.service invalid.
Unable to restart apache using ['apachectl', 'graceful']
Congratulations! You have successfully enabled HTTPS on https://ligalc.ru
- Donating to ISRG / Let's Encrypt: Donate - Let's Encrypt
- Donating to EFF: Support EFF's Work on Let's Encrypt | Electronic Frontier Foundation
[root@ligalc ~]#
The site is loading, the certificate is now until July 4th, but for some reason it says that it is not protected
from another browser it says that the certificate is available and https:// is not crossed out
You got a couple of resources loaded over http:
I did everything as it was written there, but still https:// is crossed out..
Looks like whynopadlock website doesn't check everything. You can open Network tab of Web Tools of your web browser and see which resources are still loaded over http.
Thanks everyone for the answers! Indeed, I found some more mentions of http:// on my site using the command [root@ligalc ~]# grep -rl 'http://' /var/www/html, without hesitation I forwarded it to https:// and ... finally it worked as it should learned a few lessons))
Learn this one: You don't really need to specify HTTP or HTTPS within the same site.
As a very basic example, instead of replacing: "http://my.example.com/folder/picture.jpg
with: "https://my.example.com/folder/picture.jpg
try using just: "/folder/picture.jpg
