I need to find out current rate limit adjustments for our domain
loxonecloud.com
I am trying to find out what rate limit adjustments are in effect for this domain. I tried asking via the form "rate limit adjustment request" and the answer was to ask here. I am not sure if this is the right place to ask.
Best regards,
Sladan
@sladiri, welcome to the community! :slightly_smiling_face:
Unless you asked for and granted exception (probably not, because you asked that question), the standard, default rate limit settings (Rate Limits - Let's Encrypt) are applied to your domain.
Thanks for the reply and we will take the default limits into account.
However as far as I understand, there could have been some exception granted in the past. The problem is that we want to confirm them, because there is no documenation on what was granted. What should be the way to find this out?
If the domain is not managed exclusively by you, and someone else requested change on the rate-limit, this forum is the appropriate place to ask for checking. Sometimes LE staff comes here, and they can verify it.
I see, thank you. Yes I am asking on behalf of the owner of that domain.
