My domain is:nightstar.top
I ran this command:none
It produced this output:I can’t apply for a digital certificate.
My web server is (include version):IIS
The operating system my web server runs on is (include version):Windows Server 2016
My hosting provider, if applicable, is:www.hanming.com
I’m using a control panel to manage my site (no, or provide the name and version of the control panel):yes
The version of my client is (e.g. output of certbot --version or certbot-auto --version if you’re using Certbot):I don’t Know
I am the owner of this domain name and the website it resolves.When I apply for SSL certificate with acme client called WACS,it reminds me that this domain name has been applied for certificate many times, but I didn’t do that.
If you can, I hope you can revoke the SSL certificate of the domain name and reissue it for me. If necessary, I can provide you domain name certificate or information you need.
That’s why I need help. Because I didn’t apply for these certificates at all, I didn’t have the public key and private key of these certificates, and I couldn’t use them, so I need to ask you to revoke these certificates and reissue them to my legal and correct domain name and website owner. Thank you.
I applied for buypass’s digital certificate,because I can’t apply for a digital certificate issued by Let’s Encrypt.
But actually I want to use a certificate issued by Let’s Encrypt.
So I rellay need help.
On the other hand, if I don’t need SSL certificate, can’t I ask CA to revoke the certificate that issued my domain name maliciously?
Of course, it’s just a discussion from another angle. I still need SSL certificate now.
The first time, I filled in the information and options, and passed the domain name verification of ca. however, instead of outputting the corresponding private key and file, an error message pops up.
(there is also a retry option) I tried again 3 times, but failed, so I had to give up.
The second time I tried again, the acme client exited directly when the domain name was verified, without any prompt. Then I went to a website to apply for a certificate, and the website told me that my domain name had been applied for and issued many SSL certificates recently.
So I have to use buypass’s certificate temporarily and ask you for help.
