I need a CSR for my site longboardfunds.com
My domain is: longboardfunds.com
I ran this command: NA
It produced this output: NA
My web server is (include version): NA
The operating system my web server runs on is (include version): NA
My hosting provider, if applicable, is: Adobe Business Catalyst
I can login to a root shell on my machine (yes or no, or I don’t know): NA
I assume you mean that you need a certificate. (A CSR, or Certificate Signing Request, is like an application for a CA-signed certificate.) Have you checked out the Getting Started Page?
Hi @CATKINS,
In this case it appears that your hosting provider needs to help you with this process. Adobe Business Catalyst does not appear to offer the kind of access that would allow you to do this for yourself.
I read conflicting things about the availability of support for HTTPS on a custom domain on this hosting provider, but they made an announcement earlier that it would be available during 2017:
https://www.businesscatalyst.com/bc-blog/welcome-to-the-new-face-of-business-catalyst
So you should ask the hosting provider's support about the status of this. Although you can obtain a third-party certificate (such as a Let's Encrypt certificate) for your site without the hosting provider's help, you won't be able to install it without the hosting provider's permission and/or assistance, so it wouldn't do you any good.
If Adobe Business Catalyst isn't able to allow you to use HTTPS on a custom domain, you could consider any of the hosting providers listed in the thread at
By the way, a CSR is a "certificate signing request" which is a kind of document used in some workflows as part of the process of obtaining a certificate. You won't necessarily need to use a CSR directly; what you're probably looking for is the certificate. :slight_smile:
Hi Jared
I a m hosting my site with Adobe Business Catalyst (they list “Let’s Encrypt” as Certificate Authority). now the registrar of the domain is GoDaddy for which I am pointing my domain “Longboardfunds.com” from. I have an open SSL spot there and all they require is a CSR from Adobe or in this case the Certificate Authority. So my DNS is externally hosted.
I would like to keep this setup as to not disturb configurations on 3 other sites on the domain. Please let me know if this makes sense and if Let’s Encrypt can help.
Craig Atkins | Director of Digital Engagement Strategy
mobile: (219) 588-4510
office: (602) 595-2257
LONGBOARD
longboardmutualfunds.comhttp://www.longboardmutualfunds.com/
A top company to work for in Arizona, 2016http://longboardmutualfunds.com/careers/
THIS MESSAGE IS FOR THE NAMED PERSON’S USE ONLY: It may contain confidential, proprietary or legally privileged information. No confidentiality or privilege is waived or lost by any transmission errors. If you receive this message in error, please immediately delete it and all copies of it from your system, destroy any hard copies of it and notify the sender. You must not, directly or indirectly, use, disclose, distribute, print, or copy any part of this message if you are not the intended recipient. LONGBOARD ASSET MANAGEMENT reserves the right to intercept and monitor all e-mail communications through its networks if legally allowed. Past performance is not indicative of future results. This email and the information attached hereto is for informational purposes only and is not to be considered an offer for purchase or sale of any investment product.
Are you sure about the "CSR" part? That seems like it could be a mistake and they might want a certificate rather than a CSR.
I am 100% sure regarding the CSR. GoDaddy is now requiring from the host.
LONGBOARD
OK, only the hosting provider can create the CSR because it requires access to the private key that will be used. The CSR must be signed by the private key.
