I made too many certificated by accident, how to fix it?
Hi, i host couple websites with couple domain names on the same server.
I have been using NoIP DUC for Domain Name and then CertBot to get my SSL.
Its working for my other domain, but my most important domain has ruin into a problem where i run out of certificates, i have been only renewing, and i dont think i have done it multiple times, i hope at least i didnt do it while attempting trouble shooting...
console output (i ceonsored the domain names to the first letter, domain name is normally correct and full):
C:\Program Files\Certbot>certbot renew
Saving debug log to C:\Certbot\log\letsencrypt.log
Processing C:\Certbot\renewal\f
Processing C:\Certbot\renewal\l
Processing C:\Certbot\renewal\n
Renewing an existing certificate for n
Failed to renew certificate n with error: urn:ietf:params:acme:error:rateLimited :: There were too many requests of a given type :: Error creating new order :: too many certificates (5) already issued for this exact set of domains in the last 168 hours: nimoweb.ddns.net, retry after 2023-10-04T10:49:08Z: see https://letsencrypt.org/docs/duplicate-certificate-limit/
The following certificates are not due for renewal yet:
  C:\Certbot\live\f\fullchain.pem expires on 2023-12-09 (skipped)
  C:\Certbot\live\l\fullchain.pem expires on 2023-12-09 (skipped)
  C:\Certbot\live\n\fullchain.pem (failure)
Ask for help or search for solutions at https://community.letsencrypt.org. See the logfile C:\Certbot\log\letsencrypt.log or re-run Certbot with -v for more details.
I would like to ask for any ideas how i could get the certificate to work again with the same certificate if i am able to get it, or should i create new one or do you ahve any ideas?
You have definitely been requesting too many certs. Use a site like https://crt.sh to see your history. You are getting a new cert almost every day. Something is wrong with your method. You are probably use --force-renewal when you should not be although there are other possibilities.
You will need to wait until after the time indicated in the error message. Or, try the work-around if you cannot wait. See link here
Please use the staging system when testing. This will avoid production rate limits.
I relocated your thread to the Help section. If you need further help please answer the questions below tht you would have been shown had you posted in Help first.
Yes, i see my logs and maybe i was reattempting to get renew the certificate too often.
Here is my info:
nimoweb.ddns.net
renew
Processing C:\Certbot\renewal\foxxo.ddns.net.conf
Processing C:\Certbot\renewal\lagoona.ddns.net.conf
Processing C:\Certbot\renewal\nimoweb.ddns.net.conf
Renewing an existing certificate for nimoweb.ddns.net
Failed to renew certificate nimoweb.ddns.net with error: urn:ietf:params:acme:error:rateLimited :: There were too many requests of a given type :: Error creating new order :: too many certificates (5) already issued for this exact set of domains in the last 168 hours: nimoweb.ddns.net, retry after 2023-10-04T10:49:08Z: see https://letsencrypt.org/docs/duplicate-certificate-limit/
  C:\Certbot\live\foxxo.ddns.net\fullchain.pem expires on 2023-12-09 (skipped)
  C:\Certbot\live\lagoona.ddns.net\fullchain.pem expires on 2023-12-09 (skipped)
  C:\Certbot\live\nimoweb.ddns.net\fullchain.pem (failure)
XAMPP v3.3.0 (2021-04-06)
Windows Server 2019 Datacenter Version 10.0.17763 Build 17763
selfhosted
Contabo Control Panel + Remote Desktop
certbot 2.0.0
the other domains are lagoona.ddns.net, and foxxo.ddns.net, the foxxo one i can dispose of, it was for a test for one of my studnets.
Hi @nimo, and welcome to the LE community forum :slight_smile:
What does this show?:
certbot certificates
I see that a cert was recently issued:
Thanks for the welcome ^^
certbot certificates outputs:
Found the following certs:
  Certificate Name: foxxo.ddns.net
    Serial Number: 45ba378a380e05d05eee0da3ccf3ec417b5
    Key Type: ECDSA
    Domains: foxxo.ddns.net
    Expiry Date: 2023-12-09 11:23:18+00:00 (VALID: 66 days)
    Certificate Path: C:\Certbot\live\foxxo.ddns.net\fullchain.pem
    Private Key Path: C:\Certbot\live\foxxo.ddns.net\privkey.pem
  Certificate Name: lagoona.ddns.net
    Serial Number: 3471d2a53608dece3e18849651c722b7d7e
    Key Type: ECDSA
    Domains: lagoona.ddns.net
    Expiry Date: 2023-12-09 11:23:34+00:00 (VALID: 66 days)
    Certificate Path: C:\Certbot\live\lagoona.ddns.net\fullchain.pem
    Private Key Path: C:\Certbot\live\lagoona.ddns.net\privkey.pem
  Certificate Name: nimoweb.ddns.net
    Serial Number: 3af6c1e3677b51d531fa855b26cc0988042
    Key Type: ECDSA
    Domains: nimoweb.ddns.net
    Expiry Date: 2023-09-05 10:53:50+00:00 (INVALID: EXPIRED)
    Certificate Path: C:\Certbot\live\nimoweb.ddns.net\fullchain.pem
    Private Key Path: C:\Certbot\live\nimoweb.ddns.net\privkey.pem
The first two certs were renewed 24 days ago.
Did they also use --standalone?
If so, what has changed since then [to prevent HTTP from reaching certbot]?
If not, can you renew nimoweb in that same way?
@rg305 It's a rate limit issue, not an issuance/challenge issue. For some reason the certs aren't being saved.
all 3 certificates were made at roughlt at the same time, and for i believe half a year just renewed every now and then. All created with --standalone, when i attempt to renew all of them, the 2 first ones are awaiting expiration, the nimoweb one displays the issue..
I didnt change anything, all of them are set basically exacly the same way.
What could i do to help you diagnose it more or maybe you have an idea how i could fix it?
Please use the testing environment until things improve.
Try:
certbot renew --dry-run
My prediction is the dry-run will succeed, as it won't store anything to disk. If there is an issue with certificate storage, we must look at other things, like if the directory structure in /etc/letsencrypt/ is sound for the nimoweb.ddns.net certificate.
It's Winders - LOL
Oh, right, sorry. Means I'm out tho :rofl:
When attempted it promped this:
Just like @Osiris said, it worked.
I am not sure what to do now, because if i try waiting again, and attempt remaking the certificate in a week, it will again say i overdid it :confused:
C:\Program Files\Certbot>certbot renew --dry-run
Simulating renewal of an existing certificate for foxxo.ddns.net
Simulating renewal of an existing certificate for lagoona.ddns.net
Simulating renewal of an existing certificate for nimoweb.ddns.net
Congratulations, all simulated renewals succeeded:
  C:\Certbot\live\foxxo.ddns.net\fullchain.pem (success)
  C:\Certbot\live\lagoona.ddns.net\fullchain.pem (success)
  C:\Certbot\live\nimoweb.ddns.net\fullchain.pem (success)
Could you guys give me like little step guide how to scrape everythign and set anew, maybe i will wait a week and then attempt again, maybe in the proess i did somethign wrong, i am still learning and honestly i am lost ^^
Or maybe you have a better idea?
I simply want to make it work
Please show:
attrib C:\Certbot\* /S /D
and
dir C:\Certbot\* /s
Next to what Rudy is asking, you might also find some answers in the Certbot logs. But you'd need to dig to the most recent log file without any rate limit error.
i shorten the lists of logs so it fits in a post here
C:\Program Files\Certbot>attrib C:\Certbot\* /S /D
A                    C:\Certbot\accounts\acme-staging-v02.api.letsencrypt.org\directory\f6b235d11856214dd1906d4de88480db\meta.json
A                    C:\Certbot\accounts\acme-staging-v02.api.letsencrypt.org\directory\f6b235d11856214dd1906d4de88480db\private_key.json
A                    C:\Certbot\accounts\acme-staging-v02.api.letsencrypt.org\directory\f6b235d11856214dd1906d4de88480db\regr.json
A                    C:\Certbot\accounts\acme-v02.api.letsencrypt.org\directory\e0bf52c62f3bcc2f61877600c2f9b13f\meta.json
A                    C:\Certbot\accounts\acme-v02.api.letsencrypt.org\directory\e0bf52c62f3bcc2f61877600c2f9b13f\private_key.json
A                    C:\Certbot\accounts\acme-v02.api.letsencrypt.org\directory\e0bf52c62f3bcc2f61877600c2f9b13f\regr.json
A                    C:\Certbot\archive\foxxo.ddns.net\cert1.pem
A                    C:\Certbot\archive\foxxo.ddns.net\cert2.pem
A                    C:\Certbot\archive\foxxo.ddns.net\chain1.pem
A                    C:\Certbot\archive\foxxo.ddns.net\chain2.pem
A                    C:\Certbot\archive\foxxo.ddns.net\fullchain1.pem
A                    C:\Certbot\archive\foxxo.ddns.net\fullchain2.pem
A                    C:\Certbot\archive\foxxo.ddns.net\privkey1.pem
A                    C:\Certbot\archive\foxxo.ddns.net\privkey2.pem
A                    C:\Certbot\archive\lagoona.ddns.net\cert1.pem
A                    C:\Certbot\archive\lagoona.ddns.net\cert2.pem
A                    C:\Certbot\archive\lagoona.ddns.net\chain1.pem
A                    C:\Certbot\archive\lagoona.ddns.net\chain2.pem
A                    C:\Certbot\archive\lagoona.ddns.net\fullchain1.pem
A                    C:\Certbot\archive\lagoona.ddns.net\fullchain2.pem
A                    C:\Certbot\archive\lagoona.ddns.net\privkey1.pem
A                    C:\Certbot\archive\lagoona.ddns.net\privkey2.pem
A                    C:\Certbot\archive\nimoweb.ddns.net\cert1.pem
A                    C:\Certbot\archive\nimoweb.ddns.net\cert2.pem
A                    C:\Certbot\archive\nimoweb.ddns.net\chain1.pem
A                    C:\Certbot\archive\nimoweb.ddns.net\chain2.pem
A                    C:\Certbot\archive\nimoweb.ddns.net\fullchain1.pem
A                    C:\Certbot\archive\nimoweb.ddns.net\fullchain2.pem
A                    C:\Certbot\archive\nimoweb.ddns.net\privkey1.pem
A                    C:\Certbot\archive\nimoweb.ddns.net\privkey2.pem
A                    C:\Certbot\archive\nimoweb.ddns.net-0001\cert1.pem
A                    C:\Certbot\archive\nimoweb.ddns.net-0001\chain1.pem
A                    C:\Certbot\archive\nimoweb.ddns.net-0001\fullchain1.pem
A                    C:\Certbot\archive\nimoweb.ddns.net-0001\privkey1.pem
A                    C:\Certbot\csr\0000_csr-certbot.pem
A                    C:\Certbot\csr\0340_csr-certbot.pem
A                    C:\Certbot\keys\0000_key-certbot.pem
A                    C:\Certbot\keys\0340_key-certbot.pem
A                    C:\Certbot\live\foxxo.ddns.net\cert.pem
A                    C:\Certbot\live\foxxo.ddns.net\chain.pem
A                    C:\Certbot\live\foxxo.ddns.net\fullchain.pem
A                    C:\Certbot\live\foxxo.ddns.net\privkey.pem
A                    C:\Certbot\live\foxxo.ddns.net\README
A                    C:\Certbot\live\lagoona.ddns.net\cert.pem
A                    C:\Certbot\live\lagoona.ddns.net\chain.pem
A                    C:\Certbot\live\lagoona.ddns.net\fullchain.pem
A                    C:\Certbot\live\lagoona.ddns.net\privkey.pem
A                    C:\Certbot\live\lagoona.ddns.net\README
A                    C:\Certbot\live\nimoweb.ddns.net\cert.pem
A                    C:\Certbot\live\nimoweb.ddns.net\chain.pem
A                    C:\Certbot\live\nimoweb.ddns.net\fullchain.pem
A                    C:\Certbot\live\nimoweb.ddns.net\privkey.pem
A                    C:\Certbot\live\nimoweb.ddns.net\README
A                    C:\Certbot\live\README
A                    C:\Certbot\log\letsencrypt.log
A                    C:\Certbot\log\letsencrypt.log.(0 to 340)
A                    C:\Certbot\renewal\foxxo.ddns.net.conf
A                    C:\Certbot\renewal\lagoona.ddns.net.conf
A                    C:\Certbot\renewal\nimoweb.ddns.net.conf
                     C:\Certbot\renewal-hooks\deploy
                     C:\Certbot\renewal-hooks\post
                     C:\Certbot\renewal-hooks\pre
                     C:\Certbot\accounts
                     C:\Certbot\archive
                     C:\Certbot\csr
                     C:\Certbot\keys
                     C:\Certbot\lib
                     C:\Certbot\live
                     C:\Certbot\log
                     C:\Certbot\renewal
C:\Program Files\Certbot>dir C:\Certbot\* /s
 Volume in drive C is Windows
 Volume Serial Number is 20EB-8307
 Directory of C:\Certbot
2023-10-05  06:14    <DIR>          .
2023-10-05  06:14    <DIR>          ..
2023-03-08  18:54    <DIR>          accounts
2023-06-07  13:57    <DIR>          archive
2023-10-05  06:14    <DIR>          csr
2023-10-05  06:14    <DIR>          keys
2023-10-05  06:14    <DIR>          lib
2023-09-10  14:53    <DIR>          live
2023-10-05  06:14    <DIR>          log
2023-09-10  14:28    <DIR>          renewal
2023-03-08  18:50    <DIR>          renewal-hooks
               0 File(s)              0 bytes
 Directory of C:\Certbot\accounts
2023-03-08  18:54    <DIR>          .
2023-03-08  18:54    <DIR>          ..
2023-03-08  18:54    <DIR>          acme-staging-v02.api.letsencrypt.org
2023-03-08  18:51    <DIR>          acme-v02.api.letsencrypt.org
               0 File(s)              0 bytes
 Directory of C:\Certbot\accounts\acme-staging-v02.api.letsencrypt.org
2023-03-08  18:54    <DIR>          directory
               0 File(s)              0 bytes
 Directory of C:\Certbot\accounts\acme-staging-v02.api.letsencrypt.org\directory
2023-03-08  18:54    <DIR>          f6b235d11856214dd1906d4de88480db
               0 File(s)              0 bytes
 Directory of C:\Certbot\accounts\acme-staging-v02.api.letsencrypt.org\directory\f6b235d11856214dd1906d4de88480db
2023-03-08  18:54                74 meta.json
2023-03-08  18:54             1,632 private_key.json
2023-03-08  18:54                86 regr.json
               3 File(s)          1,792 bytes
 Directory of C:\Certbot\accounts\acme-v02.api.letsencrypt.org
2023-03-08  18:51    <DIR>          .
2023-03-08  18:51    <DIR>          ..
2023-03-08  18:51    <DIR>          directory
               0 File(s)              0 bytes
 Directory of C:\Certbot\accounts\acme-v02.api.letsencrypt.org\directory
2023-03-08  18:51    <DIR>          e0bf52c62f3bcc2f61877600c2f9b13f
               0 File(s)              0 bytes
 Directory of C:\Certbot\accounts\acme-v02.api.letsencrypt.org\directory\e0bf52c62f3bcc2f61877600c2f9b13f
2023-03-08  18:52                74 meta.json
2023-03-08  18:51             1,632 private_key.json
2023-03-08  18:51                80 regr.json
               3 File(s)          1,786 bytes
 Directory of C:\Certbot\archive
2023-06-07  13:57    <DIR>          .
2023-06-07  13:57    <DIR>          ..
2023-09-10  14:23    <DIR>          foxxo.ddns.net
2023-09-10  14:23    <DIR>          lagoona.ddns.net
2023-09-10  14:23    <DIR>          nimoweb.ddns.net
2023-06-07  13:53    <DIR>          nimoweb.ddns.net-0001
               0 File(s)              0 bytes
 Directory of C:\Certbot\archive\foxxo.ddns.net
2023-09-10  14:23    <DIR>          .
2023-09-10  14:23    <DIR>          ..
2023-06-07  13:54             1,566 cert1.pem
2023-09-10  14:23             1,489 cert2.pem
2023-06-07  13:54             3,749 chain1.pem
2023-09-10  14:23             3,749 chain2.pem
2023-06-07  13:54             5,315 fullchain1.pem
2023-09-10  14:23             5,238 fullchain2.pem
2023-06-07  13:54               241 privkey1.pem
2023-09-10  14:23               241 privkey2.pem
               8 File(s)         21,588 bytes
 Directory of C:\Certbot\archive\lagoona.ddns.net
2023-06-07  13:57             1,570 cert1.pem
2023-09-10  14:23             1,493 cert2.pem
2023-06-07  13:57             3,749 chain1.pem
2023-06-07  13:57             5,319 fullchain1.pem
2023-09-10  14:23             5,242 fullchain2.pem
2023-06-07  13:57               241 privkey1.pem
               8 File(s)         21,604 bytes
 Directory of C:\Certbot\archive\nimoweb.ddns.net
2023-03-08  18:52             1,619 cert1.pem
2023-03-08  18:52             3,749 chain1.pem
2023-03-08  18:52             5,368 fullchain1.pem
2023-03-08  18:52               241 privkey1.pem
               8 File(s)         21,702 bytes
 Directory of C:\Certbot\archive\nimoweb.ddns.net-0001
2023-06-07  13:53    <DIR>          .
2023-06-07  13:53    <DIR>          ..
2023-06-07  13:53             1,570 cert1.pem
2023-06-07  13:53             3,749 chain1.pem
2023-06-07  13:53             5,319 fullchain1.pem
2023-06-07  13:53               241 privkey1.pem
               4 File(s)         10,879 bytes
 Directory of C:\Certbot\csr
2023-03-08  18:52               436 0000_csr-certbot.pem
2023-10-05  06:14               391 0340_csr-certbot.pem
             341 File(s)        136,073 bytes
 Directory of C:\Certbot\keys
2023-03-08  18:52               241 0000_key-certbot.pem
2023-10-05  06:14               241 0340_key-certbot.pem
             341 File(s)         82,181 bytes
 Directory of C:\Certbot\lib
               0 File(s)              0 bytes
 Directory of C:\Certbot\live
2023-09-10  14:53    <DIR>          .
2023-09-10  14:53    <DIR>          ..
2023-09-10  14:33    <DIR>          nimoweb.ddns.net
2023-03-08  18:52               754 README
               1 File(s)            754 bytes
 Directory of C:\Certbot\live\foxxo.ddns.net
2023-09-10  14:23    <SYMLINK>      cert.pem [..\..\archive\foxxo.ddns.net\cert2.pem]
2023-09-10  14:23    <SYMLINK>      chain.pem [..\..\archive\foxxo.ddns.net\chain2.pem]
2023-09-10  14:23    <SYMLINK>      fullchain.pem [..\..\archive\foxxo.ddns.net\fullchain2.pem]
2023-09-10  14:23    <SYMLINK>      privkey.pem [..\..\archive\foxxo.ddns.net\privkey2.pem]
2023-06-07  13:54               706 README
               5 File(s)            706 bytes
 Directory of C:\Certbot\live\lagoona.ddns.net
2023-09-10  14:23    <SYMLINK>      cert.pem [..\..\archive\lagoona.ddns.net\cert2.pem]
2023-09-10  14:23    <SYMLINK>      chain.pem [..\..\archive\lagoona.ddns.net\chain2.pem]
2023-09-10  14:23    <SYMLINK>      fullchain.pem [..\..\archive\lagoona.ddns.net\fullchain2.pem]
2023-09-10  14:23    <SYMLINK>      privkey.pem [..\..\archive\lagoona.ddns.net\privkey2.pem]
2023-06-07  13:57               706 README
               5 File(s)            706 bytes
 Directory of C:\Certbot\live\nimoweb.ddns.net
2023-09-10  14:33    <DIR>          .
2023-09-10  14:33    <DIR>          ..
2023-09-10  14:23    <SYMLINK>      cert.pem [..\..\archive\nimoweb.ddns.net-0001\cert1.pem]
2023-09-10  14:23    <SYMLINK>      chain.pem [..\..\archive\nimoweb.ddns.net-0001\chain1.pem]
2023-09-10  14:23    <SYMLINK>      fullchain.pem [..\..\archive\nimoweb.ddns.net-0001\fullchain1.pem]
2023-09-10  14:23    <SYMLINK>      privkey.pem [..\..\archive\nimoweb.ddns.net-0001\privkey1.pem]
2023-06-07  13:53               706 README
               5 File(s)            706 bytes
 Directory of C:\Certbot\log
2023-10-05  06:14            13,439 letsencrypt.log [ 0 to 340 ]
             443 File(s)      8,406,093 bytes
 Directory of C:\Certbot\renewal
2023-09-10  14:28    <DIR>          .
2023-09-10  14:28    <DIR>          ..
2023-09-10  14:23               514 foxxo.ddns.net.conf
2023-09-10  14:23               524 lagoona.ddns.net.conf
2023-09-10  14:23               524 nimoweb.ddns.net.conf
               3 File(s)          1,562 bytes
 Directory of C:\Certbot\renewal-hooks
2023-03-08  18:50    <DIR>          .
2023-03-08  18:50    <DIR>          ..
2023-03-08  18:50    <DIR>          deploy
2023-03-08  18:50    <DIR>          post
2023-03-08  18:50    <DIR>          pre
               0 File(s)              0 bytes
 Directory of C:\Certbot\renewal-hooks\deploy
               0 File(s)              0 bytes
 Directory of C:\Certbot\renewal-hooks\post
               0 File(s)              0 bytes
 Directory of C:\Certbot\renewal-hooks\pre
               0 File(s)              0 bytes
     Total Files Listed:
            1178 File(s)      8,708,132 bytes
              77 Dir(s)  34,101,936,128 bytes free
I tried looking through logs that the error message was prompting, sadly all i learned is to check the user manual online...
I explicitely asked for a log WITHOUT the error message.
