I am newbie here , steps with command wolud be more helpfull , thanks in advance
They are both already PEM-encoded, which is the usual format expected for a file with the .crt extension. The giveaway is the BEGIN and END headers.
If your web server expects the private key and certificate to be in a single file (such as what haproxy does), then you can just concatenate one PEM-encoded block after another into a single file.
Be very careful where you place the private key.
If you include it within a file intended only for public view, you will basically give away the keys to your (encryption) kingdom.
