My domain is: forumi.im
I ran this command: ./discourse-setup in /var/discourse with docker
My web server is (include version): Linux
The operating system my web server runs on is (include version): Ubuntu 18.4
My hosting provider, if applicable, is: contabo
ps : i thing I have hit the Let’s Encrypt limit with my domain forumi.im and i can only install with some subdomain,
is a forum. If you don't know how to install the forum in your main domain, please use the discourse forum.
If you use docker, you have to save the account and certificates on a permanent device. So you can destroy your container an re-use the certificate. If you have hit the limit, your configuration is wrong. Use the test system to change / update your setup.
Yes is true i have destroy my container have reinstall my server, and now i need only to generate new subdomain to reinstall it, Because I can’t do it with the main domain so not in example : meet.forumi.im but in main domain forumi.im or www.forumi.im.
Discourse forum support I advise to turn to you, Because they think the problem lies in regenerating the certificate
I have nothing to lose on the server i can try reinstalling it, but i’m afraid that if i re-set my domain it won’t work
@JuergenAuer I appreciate your time and patience, and i would like to ask if it’s possible? to delete any certificate i created in order for me to tey to create them from the beginning!
