I am trying to issue https certificate using certbot certonly --manual, but it says that "Certbot failed to authenticate some domains"
My domain is: 9.cr
I ran this command: certbot certonly --manual
Domain: 9.cr
Type: dns
Detail: DNS problem: looking up A for 9.cr: DNSSEC: DNSKEY Missing; DNS problem: looking up AAAA for 9.cr: DNSSEC: DNSKEY Missing
Hint: The Certificate Authority failed to verify the manually created challenge files. Ensure that you created these in the correct location.
The operating system my web server runs on is (include version): Ubuntu 22.04.3 LTS
The version of my client is (e.g. output of certbot --version or certbot-auto --version if you're using Certbot): 1.21.0
Logs in the /var/log/letsencrypt/letsencrypt.log:
DEBUG:certbot._internal.display.obj:Notifying user: No renewals were attempted.
DEBUG:certbot._internal.display.obj:Notifying user: - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - -
DEBUG:certbot._internal.renewal:no renewal failures
DEBUG:certbot._internal.main:certbot version: 1.21.0
DEBUG:certbot._internal.main:Location of certbot entry point: /usr/bin/certbot
DEBUG:certbot._internal.main:Arguments: ['-q']
DEBUG:certbot._internal.main:Discovered plugins: PluginsRegistry(PluginEntryPoint#manual,PluginEntryPoint#null,PluginEntryPoint#standalone,PluginEntryPoint#webroot)
DEBUG:certbot._internal.log:Root logging level set at 40
DNSSEC is severely broken for your domain name.
See also e.g. 9.cr | DNSViz.
Hello @Krinix,
Adding to @Osiris, correct analysis:
https://zonemaster.net/en/result/81e4f571b4044858
https://ednscomp.isc.org/ednscomp/afcf3f3ad8
https://dnsviz.net/d/9.cr/dnssec/
